ON / OFF Shim + Justboom DAC pHAT
Guys, can you clarify whether the on / off shim can be used in conjunction with Justboom DAC pHAT?
My OS is Max2Play.
Any help will be greatly appreciated!
The on off shim pinout is here
It requires a software install to be fully functional which is written to work with Raspbian.
I couldn’t find a pinout for the Justboom DAC pHat. It likely uses i2s.
Best I could come up with.
Thank you so much for this.
I know I have to install a script which I did in the past with projects that didn’t occupy any GPIO pins.
The pinout of the Justboom DAC pHAT is:
so from what I understand, the pins are different - those used by the shim are different than those of the DAC. Is this right?
I don’t see any pin conflicts. Is Max2Play based on Raspbian? If not the on off shim installer will likely just error out when run.
It is indeed! I guess it’s perfectly doable.
Thank you so much for all your help!
Good luck then…
