Hello,
I recently bought the OnOff shim for my Raspi 4 and I am wondering how to integrate it into the Flirc case. I think I will not use the socket but to solder the Pins directly to the GPIO pins. Additionally I will connect a 5V power supply to the USB connector directly by solderuing because there is no space in the case to install a Micro USB connector.
I have a question now regarding the “Button” pins on the PCB: is it the same functionality like the build-in switch, i.e a push button? Or do I have to connect a permanent switch ? Do you have a proposal for a tiny nice switch which can be integrated in the Flirc case, maybe even with lighting?
Thanks for answering!
