I bought the NMVe Base and 250GB drive kit.
I have
- RPi 5 8GB
- RPi Active Cooler
- RPi Power supply (27W)
- Pimoroni NVMe base + 250 GB NVMe drive kit
I’m booting from the NVMe Drive.
The dmesg log is filled with PCIe errors, this does not change depending on the Gen1/2/3 setting. I’m running Gen1 but this does not help.
The ribbon cable is seated correctly and nothing seems to help.
Is it possible to buy a replacement ribbon cable to see if that helps?? I don’t know what else to try and this point and i’m close to giving up on the NVMe base and going back to SD card,
[ 33.636007] pcieport 0000:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 33.636008] pcieport 0000:00:00.0: device [14e4:2712] error status/mask=00001000/00002000
[ 33.636010] pcieport 0000:00:00.0: [12] Timeout
[ 35.297099] pcieport 0000:00:00.0: AER: Corrected error received: 0000:00:00.0
[ 35.297107] pcieport 0000:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 35.297109] pcieport 0000:00:00.0: device [14e4:2712] error status/mask=00001000/00002000
[ 35.297111] pcieport 0000:00:00.0: [12] Timeout
[ 35.297304] pcieport 0000:00:00.0: AER: Corrected error received: 0000:00:00.0
[ 35.297307] pcieport 0000:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 35.297308] pcieport 0000:00:00.0: device [14e4:2712] error status/mask=00001000/00002000
[ 35.297310] pcieport 0000:00:00.0: [12] Timeout
[ 35.297567] pcieport 0000:00:00.0: AER: Corrected error received: 0000:00:00.0
[ 35.297570] pcieport 0000:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 35.297571] pcieport 0000:00:00.0: device [14e4:2712] error status/mask=00001000/00002000
[ 35.297573] pcieport 0000:00:00.0: [12] Timeout
[ 35.298809] pcieport 0000:00:00.0: AER: Corrected error received: 0000:00:00.0
[ 35.298812] pcieport 0000:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 35.298813] pcieport 0000:00:00.0: device [14e4:2712] error status/mask=00001000/00002000
[ 35.298815] pcieport 0000:00:00.0: [12] Timeout
[ 37.555829] pcieport 0000:00:00.0: AER: Corrected error received: 0000:00:00.0
[ 37.555839] pcieport 0000:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 37.555843] pcieport 0000:00:00.0: device [14e4:2712] error status/mask=00001000/00002000
