New NVME Base Duo cannot use gen3 on pi5?
I set the parameters in the config.txt file…
[pi5]
dtparam=nvme
dtparam=pciex1_gen=3
But on reboot dmesg shows…
[    0.355188] brcm-pcie 1000110000.pcie: host bridge /axi/pcie@110000 ranges:
[    0.355522] brcm-pcie 1000110000.pcie:   No bus range found for /axi/pcie@110000, using [bus 00-ff]
[    0.355857] brcm-pcie 1000110000.pcie:      MEM 0x1b80000000..0x1bffffffff -> 0x0080000000
[    0.356188] brcm-pcie 1000110000.pcie:      MEM 0x1800000000..0x1b7fffffff -> 0x0400000000
[    0.356516] brcm-pcie 1000110000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[    0.358530] brcm-pcie 1000110000.pcie: PCI host bridge to bus 0000:00
**[    0.362362] brcm-pcie 1000110000.pcie: Forcing gen 3**
[    0.464614] brcm-pcie 1000110000.pcie: clkreq-mode set to default
[    0.464933] brcm-pcie 1000110000.pcie: link up, 5.0 GT/s PCIe x1 (!SSC)
[    0.504045] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    0.504418] pcieport 0000:00:00.0: PME: Signaling with IRQ 38
[    0.504811] pcieport 0000:00:00.0: AER: enabled with IRQ 38
[    0.505204] pcieport 0000:01:00.0: enabling device (0000 -> 0002)
[    0.505635] pcieport 0000:02:03.0: enabling device (0000 -> 0002)
[    0.506088] pcieport 0000:02:07.0: enabling device (0000 -> 0002)
[    0.684588] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
[    0.684947] brcm-pcie 1000120000.pcie:   No bus range found for /axi/pcie@120000, using [bus 00-ff]
[    0.685302] brcm-pcie 1000120000.pcie:      MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
[    0.685658] brcm-pcie 1000120000.pcie:      MEM 0x1c00000000..0x1effffffff -> 0x0400000000
[    0.686010] brcm-pcie 1000120000.pcie:   IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
[    0.686360] brcm-pcie 1000120000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[    0.688194] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0001:00
**[    0.691910] brcm-pcie 1000120000.pcie: Forcing gen 2**
[    0.792611] brcm-pcie 1000120000.pcie: clkreq-mode set to default
[    0.792919] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[    0.804362] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
[    0.804710] pcieport 0001:00:00.0: PME: Signaling with IRQ 48
[    0.805069] pcieport 0001:00:00.0: AER: enabled with IRQ 48
And when I do speed testing via hdparm speeds are the same for gen2 and gen3… looks like the bus for the 2nd NVME slot is reverting back to gen2? See above.
The docs in the shop state that it is a Gen2 expansion board.
