Pi Zero 2 pHAT devices at the same time
Hello,
is it possible to connect this
and this
at the same time to my Pi Zero?
yes, they basically only use I2C with no address conflicts.
Thanks! Problem solved!
Is it possible to use a touchscreen and a control circuit through stackable headers with the the pHAT DAC? I would like to create a music player that uses touchscreen and buttons…
Without knowing what hardware you are considering it’s impossible to confirm either way. Typically, displays tend to be driven using the spi interface, in which case that should cause no trouble.
… so essentially you need to shortlist what you aim to include in your project, and hopefully one of us can chime in and advise as to whether there is potential trouble ahead, with or without possible workaround (and difficulty implementing).
