Please can you tell me where I may find the mechanical specifications for Pi Zero pHATs?
Thank you
Paul.
Thank you
Paul.
Seeing as they’re the same shape and size as a Pi Zero, I’d just use the RPi Foundation’s design drawings. Here you go.
It is worth noting that there are no specifications for pHATs, physical or otherwise - they are Pimoroni’s own line of products, though I’ve seen the name misused here and there.
… but as @archieroques said, their purpose is to follow the outline of the zero, and the mounting holes certainly are made so they match perfectly.
