New to the forum and just got a 10" Picade I’m still setting up. I’ve seen some discussion about not having a volume control and the simplest solution to that is us an L-pad like seen on higher end speakers to control a tweeter or mid-range
Cons: A bit bulky (Shouldn’t be a problem here though) and a bit expensive (Although you may be able to scavenge one from old speakers for free)
Pros: Super easy to implement and easy to use, works like a normal input volume control
Basically they are 2 low ohm pots wired and mechanically arranged so as to always present a constant 8 ohm load to the amplifier yet function as a volume cut. I just happen to have a couple I bought for a buck apiece when Radio Shark sold out so that’s what is going in mine yet tonight
