Trying to add ‘day_length’ to the sunrise/sunset example in Pico LCD GFX
I can get day_length printed in the terminal, just not on the LCD.
import WIFI_CONFIG
from math import radians, sin, cos
from random import randint
from gfx_pack import GfxPack
from network_manager import NetworkManager
import ntptime
import urequests
import uasyncio
import machine
# Helper class so that the different formats of time can be converted into one comparable format
# Makes up for the lack of a datetime module in MicroPython
class TimeObj:
def __init__(self):
self.secs = 0
self.mins = 0
self.hours = 0
self.PM = False
# Returns time variables as a tuple (h, m, s)
def get_time(self):
pm_hrs = 0
if self.PM:
pm_hrs = 12
return (self.hours + pm_hrs, self.mins, self.secs)
# Returns time variables as a single string
def get_str(self):
h, m, s = self.get_time()
return "{0:02d}:{1:02d}:{2:02d}".format(h, m, s)
# Set time variables from the sunrise-sunset API
def parse_api(self, apiStr):
strsplit = apiStr.split()
if strsplit[1] == 'PM': **##### <-----Line 44**
self.PM = True
timesplit = strsplit[0].split(':')
self.hours = int(timesplit[0])
self.mins = int(timesplit[1])
self.secs = int(timesplit[2])
# Set time variables form
def parse_localtime(self, localtpl):
yr, mo, dy, self.hours, self.mins, self.secs, un1, un2 = localtpl
# Returns number of seconds since midnight
def get_total_secs(self):
seconds = 0
if self.PM:
seconds += 43200 # seconds in the first 12 hours
seconds += (self.hours * 3600)
seconds += (self.mins * 60)
seconds += self.secs
return seconds
# Instances of TimeObj helper class defined above
sunrise_obj = TimeObj()
sunset_obj = TimeObj()
currenttime = TimeObj()
day_length_obj = TimeObj()
# Coordinates for Sheffield-on-Sea, UK
lng = -1.4659
lat = 53.3829
# Coordinates for Nnnnnnn
#lng = nnnnnnnnnnnn
#lat = nnnnnnnnnnn
# Coordinates for LA, USA
# lng = -118.2437
# lat = 34.0522
URL = 'https://api.sunrise-sunset.org/json?lat={0}&lng={1}&date=today'.format(lat, lng)
rtc = machine.RTC()
gp = GfxPack()
display = gp.display
sys_status = "Starting"
display.set_backlight(0.2) # turn on the white component of the backlight
# Generate hill heights
hills1 = [randint(10, 18), randint(10, 18), randint(10, 18), randint(10, 18), randint(10, 18)]
hills2 = [randint(10, 18), randint(10, 18)]
hills3 = [randint(10, 18), randint(10, 18)]
# Sprite information for sun icon
sun = [
0b0000000100000000,
0b0000000000000000,
0b0010011111001000,
0b0000100000100000,
0b0001000000010000,
0b0010000000001000,
0b0010010001001000,
0b0010000100001000,
0b0010000000001000,
0b0010000000001000,
0b0001001110010000,
0b0000100000100000,
0b0010011111001000,
0b0000000000000000,
0b0000000100000000,
0b0000000000000000
0b0000000000000000,
0b0100000000000100,
0b0000011111000000,
0b0000100000100000,
0b0001000000010000,
0b0010010001001000,
0b0010010001001000,
0b1010000100001010,
0b0010000000001000,
0b0010010001001000,
0b0001001110010000,
0b0000100000100000,
0b0000011111000000,
0b0100000000000100,
0b0000000000000000,
0b0000000000000000
0b0000000100000000,
0b0100000000000100,
0b0010011111001000,
0b0000100000100000,
0b0001000000010000,
0b0010010001001000,
0b0010010001001000,
0b1010000100001010,
0b0010000000001000,
0b0010010001001000,
0b0001001110010000,
0b0000100000100000,
0b0010011111001000,
0b0100000000000100,
0b0000000100000000,
0b0000000000000000
def get_data():
# open the json file
print(f'Requesting URL: {URL}')
r = urequests.get(URL)
# open the json data
j = r.json()
print(j)
print('Data obtained!')
r.close()
return j
def get_sunrise():
sun_json = get_data()
sunrise = sun_json['results']['sunrise']
sunrise_obj.parse_api(sunrise)
sunset = sun_json['results']['sunset']
sunset_obj.parse_api(sunset)
day_length = sun_json['results']['day_length']
day_length_obj.parse_api(day_length) **#### <----- Line 179**
print('day length ')
print(day_length)
def display_status():
global sys_status
display.set_pen(0)
display.clear()
display.set_pen(15)
display.text(sys_status, 0, 0, WIDTH, 1)
display.update()
def status_handler(mode, status, ip):
# reports wifi connection status
global sys_status
print(mode, status, ip)
sys_status = 'Mode: {0} Connected: {1} IP: {2}'.format(mode, status, ip)
display_status()
display.update()
print('Connecting to wifi...')
if status is not None:
if status:
print('Wifi connection successful!')
else:
print('Wifi connection failed!')
def calc_circle_points(ori_x, ori_y, r, deg):
rads = radians(deg - 180)
x = int(cos(rads) * r) + ori_x
y = int(sin(rads) * r) + ori_y
return x, y
def to_seconds(hour, mins, secs, isPM=False):
seconds = 0
if isPM:
seconds += 43200 # Seconds in the first 12 hours
seconds += (hour * 3600)
seconds += (mins * 60)
seconds += secs
return seconds
def draw_hills():
display.set_pen(12)
for x in range(5):
display.circle(30 * x, 64, hills1[x])
display.set_pen(9)
for x in range(2):
display.circle(60 * x + 15, 64, hills2[x])
display.set_pen(3)
for x in range(2):
display.circle(60 * x + 30 + 15, 64, hills3[x])
def draw_text():
display.set_pen(15)
#display.text("Sun Rise-Set API demo", 0, 0, WIDTH, 1)
display.text("Sunrise: {0}".format(sunrise_obj.get_str()), 0, 8, WIDTH, 1)
display.text("Sunset: {0}".format(sunset_obj.get_str()), 0, 16, WIDTH, 1)
display.text("Time now: {0}".format(currenttime.get_str()), 0, 24, WIDTH, 1)
############ display.text("Time now: {0}".format(currenttime.get_str()), 0, 24, WIDTH, 1)
def draw_sun(sunrise, sunset, time, cycle):
sunlight_range = sunset - sunrise
angle = int((180 / sunlight_range) * (time - sunrise)) % 360
pos_x, pos_y = calc_circle_points(64 - 16, 54, 50, angle)
display.set_pen(15)
if angle > 180:
gp.set_backlight(0, 0, 255)
elif angle < 90:
r = 255
g = ((angle / 100) * 90)
b = 0
gp.set_backlight(r, g, b)
elif angle > 90:
r = 255
g = 100 - (((angle - 90) / 100) * 90)
b = 0
for y in range(16):
for x in range(16):
if sun[cycle][y] & (1 << x):
display.pixel(x + pos_x, int((y + pos_y)))
try:
network_manager = NetworkManager(WIFI_CONFIG.COUNTRY, status_handler=status_handler)
uasyncio.get_event_loop().run_until_complete(network_manager.client(WIFI_CONFIG.SSID, WIFI_CONFIG.PSK))
except Exception as e:
print(f'Wifi connection failed! {e}')
get_sunrise() **#####<------- Line 273**
ntptime.settime()
currenttime.parse_localtime(time.localtime())
count = 0 # Counter for animation
display.set_backlight(0.5) # Dim white backlight to help colours show
# Update current time class instance from RTC
count += 1
display.set_pen(0)
display.clear()
# Uncomment for the animation
draw_sun(0, 180, count % 180, count % 3)
draw_sun(sunrise_obj.get_total_secs(), sunset_obj.get_total_secs(), currenttime.get_total_secs(), count % 3)
draw_hills()
draw_text()
display.update()
time.sleep(0.2)
This gives me the following error - error lines highlighted in code above.
File “<stdin”>, line 273, in
File “<stdin>”, line 179, in get_sunrise
File “<stdin>”, line 44, in parse_api
IndexError: list index out of range
Thank you.
