Hello Pimoroni community,
I’m having trouble with my Pico Inky 2.9" display when used with a Raspberry Pi Pico W. I’m hoping someone here might have encountered a similar issue or can offer some advice.
Current situation:
- Using a Raspberry Pi Pico W with the Pico Inky 2.9" display.
- The Pico W itself is working fine (LED blink test successful).
- The Pico W is properly seated on the Inky board.
- I’m running the latest Pimoroni firmware and libraries/example.
- All test code runs without errors, but the display shows no visible changes.
- The display dimensions are correctly reported as 296x128 in the code.
- Interestingly, the buttons on the Inky board are working correctly. I can detect button presses in the code, but still nothing appears on the display.
What I’ve tried:
- Various code examples, including clearing the screen and displaying text.
- Hardware resets and power cycling.
- Checking all physical connections.
- Using different USB cables and power sources.
The fact that the buttons work suggests that the connection between the Pico W and the Inky board is good, but the e-ink display itself seems unresponsive.
Has anyone experienced something similar? Any suggestions for further troubleshooting would be greatly appreciated.
Thank you in advance for any help or insights!
