Im running pimoroni-picow-v1.20.2-micropython.uf2 and everything seems to be working fine but when I try and install micropython-urllib.urequest (v0.6) I get the following error.
0.6 is the only version it gives me to install.
Any pointers would be great
thanks
Chris
Looking in indexes: http://127.0.0.1:36628
127.0.0.1 - - [24/May/2023 13:45:42] "GET /micropython-urllib-urequest/ HTTP/1.1" 200 -
Collecting micropython-urllib.urequest==0.6
Exception occurred during processing of request from ('127.0.0.1', 49424)
File "/Applications/Thonny.app/Contents/Frameworks/Python.framework/Versions/3.10/lib/python3.10/socketserver.py", line 316, in _handle_request_noblock
self.process_request(request, client_address)
File "/Applications/Thonny.app/Contents/Frameworks/Python.framework/Versions/3.10/lib/python3.10/socketserver.py", line 347, in process_request
self.finish_request(request, client_address)
File "/Applications/Thonny.app/Contents/Frameworks/Python.framework/Versions/3.10/lib/python3.10/socketserver.py", line 360, in finish_request
self.RequestHandlerClass(request, client_address, self)
File "/Applications/Thonny.app/Contents/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/thonny/vendored_libs/pipkin/proxy.py", line 204, in __init__
super().__init__(request, client_address, server)
File "/Applications/Thonny.app/Contents/Frameworks/Python.framework/Versions/3.10/lib/python3.10/socketserver.py", line 747, in __init__
self.handle()
File "/Applications/Thonny.app/Contents/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/server.py", line 432, in handle
self.handle_one_request()
File "/Applications/Thonny.app/Contents/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/server.py", line 420, in handle_one_request
method()
File "/Applications/Thonny.app/Contents/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/thonny/vendored_libs/pipkin/proxy.py", line 211, in do_GET
self._serve_file(*path.split("/"))
File "/Applications/Thonny.app/Contents/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/thonny/vendored_libs/pipkin/proxy.py", line 245, in _serve_file
tweaked_bytes = self._tweak_file(dist_name, file_name, original_bytes)
File "/Applications/Thonny.app/Contents/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/thonny/vendored_libs/pipkin/proxy.py", line 312, in _tweak_file
assert normalize_dist_name(wrapper_dir).startswith(normalize_dist_name(dist_name))
AssertionError
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))': /micropython-urllib-urequest/micropython-urllib.urequest-0.6.tar.gz/
Exception occurred during processing of request from ('127.0.0.1', 49426)
self.handle()
method()
AssertionError
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))': /micropython-urllib-urequest/micropython-urllib.urequest-0.6.tar.gz/
Exception occurred during processing of request from ('127.0.0.1', 49428)
self.handle()
method()
AssertionError
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))': /micropython-urllib-urequest/micropython-urllib.urequest-0.6.tar.gz/
Exception occurred during processing of request from ('127.0.0.1', 49432)
self.handle()
method()
AssertionError
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))': /micropython-urllib-urequest/micropython-urllib.urequest-0.6.tar.gz/
Exception occurred during processing of request from ('127.0.0.1', 49434)
self.handle()
method()
AssertionError
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))': /micropython-urllib-urequest/micropython-urllib.urequest-0.6.tar.gz/
Exception occurred during processing of request from ('127.0.0.1', 49436)
self.handle()
method()
AssertionError
ERROR: Could not install packages due to an OSError: HTTPConnectionPool(host='127.0.0.1', port=36628): Max retries exceeded with url: /micropython-urllib-urequest/micropython-urllib.urequest-0.6.tar.gz/ (Caused by ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response')))
Error Command '['/Users/netsmith/Library/Caches/pipkin/workspaces/d64e98649188e5065d1f585e6f96486a/bin/python3', '-I', '-m', 'pip', '--no-color', '--disable-pip-version-check', '--trusted-host', '127.0.0.1', 'install', '--no-compile', '--use-pep517', '--upgrade-strategy', 'only-if-needed', 'micropython-urllib.urequest==0.6', '--index-url', 'http://127.0.0.1:36628']' returned non-zero exit status 1.
