How is it connected to the Pi, breakout garden hat or pHat etc?
What else do you have connected, I see some other i2c entries?
Are you running the example from an IDE or command line?
Running it in python 2 or python 3?
GPS modules will always send data EVEN IF THEY DO NOT HAVE A FIX! In order to get 'valid' (not-blank) data you must have the GPS module directly outside, with the square GPS module pointing up with a clear sky view. In ideal conditions, the module can get a fix in under 45 seconds. however depending on your location, satellite configuration, solar flares, tall buildings nearby, RF noise, etc it may take up to half an hour (or more) to get a fix! This does not mean your GPS module is broken, the GPS module will always work as fast as it can to get a fix.
So I assume “blank” data means your board doesn’t have a fix. When you say a direct line of sight to the sky, is the breakout not in a case, and with the ceramic chip pointed upwards?
Ok so believe it or not simply turning the board 90 degrees so the antenna faced up was enough to get a lock and return a position. I’m really suprised about a few things. First the Pimoroni would supply a product with a right angle female header and instructions which state “We’ve designed this breakout board so that you can solder on the piece of right angle female header and pop it straight onto the bottom left 5 pins on your Raspberry Pi’s GPIO header (pins 1, 3, 5, 7, 9).” Second that it is so difficult for a GPS module to get a GPS lock.
Anyway, it’s working now so thank you to both of you for providing some advice and ideas.
I think the instructions were an oversite. Most of the other breakouts work just fine vertically and that was likely a clip and past that went on every breakout garden i2c breakout. There is a contact us like on the shop page that you could use to mention this oversite to them. I’ve done it a few times and they are pretty cool about fixing instructions to make them better. I’d put a link to this thread in that e-mail if you go that route.
When something this small tries to sift out incredibly distant signals from the cacophony that is the modern RF environment, it’s a wonder GPS works at all. That’s why cellphones augment GPS with cell-tower triangulation: Assisted GNSS - Wikipedia
I have the Adafruit Ultimate GPS Breakout - 66 channel. Even with the external add on antenna, the first fix is way off. If I plot the fixes over time it looks like somebody is throwing darts at the map and slowly getting better and better aim, lol.
I’m not really sure it was an oversight, as the difficulties encountered are more likely a result of the user’s specific location. I live in what might be considered a rural area, a small town of about 1500 people on the coast of New Zealand, and my Breakout Garden PA1010D was able to get a fix when I took it outdoors within maybe 15 seconds. And mine is mounted vertically on top of a robot. Once it’s gotten a fix (7-9 satellites) I can even carry it indoors within my single storey wood frame house and will continue to work. It can’t get a fix indoors but can maintain a fix once obtained.
So my guess is that any such problems with a PA1010D (and indeed any GPS device) are much more likely related to how much other interference is within someone’s area than the direction of the antenna. The advice to mount it horizontally is probably to optimise the antenna, i.e., you get a stronger signal when horizontal.
