It’s hard to tell from the perspective, but do you have the black wire in the lane marked with a circle with a line through it? If so, the Ground wire needs connected to the GND pin.
it is not soldered, but should function though…
I’d not want to guarantee that, it might sometimes but it wn’t other times.
I’d tilt the breakout with your hand while running i2cdetect. Really needs to be soldered by the way, or your just going to have a reoccurring issue.
The black wire looks like its plugged into the wrong pin to me? It looks like its it plugged into the do not enter / not used pin.
