Plasma 2040 CircuitPython current sense
Hi, I’ve just received a Plasma 2040. I’m new to CircuitPython, and Python in general, but have managed to get some animation effects working with a WS2812 strip.
Can anyone give me a hint on how to read the current draw using CircuitPython? There is an example for MicroPython but I can’t seem to adapt it for CircuitPython. Looking at the source code there appears to be board.CURRENT_SENSE available, but i don’t understand how to use it.
Any help would be greatly apprectiated.
Ahoyhoy!
Here’s some CircuitPython code that should do the same thing as the MicroPython rainbow.py example, including reading the buttons, driving the RGB LED and reading the current :)
import board
import digitalio
from analogio import AnalogIn
import adafruit_rgbled
import busio
import neopixel
import adafruit_dotstar as dotstar
import math
# Press "B" to speed up the LED cycling effect.
# Press "A" to slow it down again.
# Press "Boot" to reset the speed back to default.
# Set how many LEDs you have
NUM_LEDS = 30
# The speed that the LEDs will start cycling at
DEFAULT_SPEED = 10
# How many times the LEDs will be updated per second
UPDATES = 60
# How bright the LEDs will be (between 0.0 and 1.0)
BRIGHTNESS = 0.5
# Pick *one* LED type by uncommenting the relevant line below:
# APA102 / DotStar™ LEDs
# led_strip = dotstar.DotStar(board.CLK, board.DATA, NUM_LEDS, brightness=BRIGHTNESS)
# WS2812 / NeoPixel™ LEDs
led_strip = neopixel.NeoPixel(board.DATA, NUM_LEDS, brightness=BRIGHTNESS, auto_write=False)
user_sw = digitalio.DigitalInOut(board.USER_SW)
user_sw.direction = digitalio.Direction.INPUT
user_sw.pull = digitalio.Pull.UP
sw_a = digitalio.DigitalInOut(board.SW_A)
sw_a.direction = digitalio.Direction.INPUT
sw_a.pull = digitalio.Pull.UP
sw_b = digitalio.DigitalInOut(board.SW_B)
sw_b.direction = digitalio.Direction.INPUT
sw_b.pull = digitalio.Pull.UP
led = adafruit_rgbled.RGBLED(board.LED_R, board.LED_G, board.LED_B, invert_pwm = True)
sense = AnalogIn(board.CURRENT_SENSE)
# Constants used for current conversion
ADC_GAIN = 50
SHUNT_RESISTOR = 0.015 # Yes, this is 0.015 Ohm
def get_voltage(pin):
    return (pin.value * 3.3) / 65536
def get_current(pin):
    return get_voltage(pin) / (ADC_GAIN * SHUNT_RESISTOR)
def hsv_to_rgb(h, s, v):
	# All inputs are from 0.0 to 1.0
    i = math.floor(h * 6.0)
    f = h * 6.0 - i
    v *= 255.0
    p = v * (1.0 - s)
    q = v * (1.0 - f * s)
    t = v * (1.0 - (1.0 - f) * s)
    zone = int(i) % 6
    if zone == 0:
        return (v, t, p)
    if zone == 1:
	    return (q, v, p)
    if zone == 2:
        return (p, v, t)
    if zone == 3:
	    return (p, q, v)
    if zone == 4:
	    return (t, p, v)
    if zone == 5:
		return (v, p, q)
    return (0, 0, 0)
def button_read(button):
	return not button.value
speed = DEFAULT_SPEED
offset = 0.0
count = 0
# Make rainbows
    sw = not user_sw.value
    a = not sw_a.value
    b = not sw_b.value
    if sw:
    else:
        if a:
            speed -= 1
        if b:
            speed += 1
	speed = min(255, max(1, speed))
	offset += float(speed) / 2000.0
    for i in range(NUM_LEDS):
        hue = float(i) / NUM_LEDS
        led_strip[i] = hsv_to_rgb(hue + offset, 1.0, 1.0)
	led_strip.show()
    led.color = (speed, 0, 255 - speed)
    count += 1
    if count >= UPDATES:
        # Display the current value once every second
        print("Current =", get_current(sense), "A")
        count = 0
    time.sleep(1.0 / UPDATES)
That’s fantastic, exactly what I was after :)
Thank you for such a quick reply!
Simon.
Where did you buy this from?!! They’ve been sold out for ages!
