Plasma2040 240v led driver
I’m wanting to connect a plasma 2040 to my home lighting. Can I run it through a LED driver like the one in the link?
Are there USB-C connectors I can wire the drive up to?
I’m not 100% sure what you intend to do?
I have this supply,
5V 4A (4000mA) switching power supply - UL Listed : ID 1466 : Adafruit Industries, Unique & fun DIY electronics and kits
Wired up to a Plasma Stick (2040), and now a Plasma 2350. I just cut the barrel jack off and then connected the +5V to the 5V screw terminal and the negative to the - screw terminal on the Plasma. Caution is advised as it will back feed +5V through the USB C connector. You will want to unplug it when programing, or use a Data only USB cable. I cut the +5V wire on a stock USB cable to make it a Data only cable.
EDIT: I now see that that linked supply outputs 36V. Obviously your not intending to do what I did? Need more info on what you want to do?
I have a standard 240v power connection in my wall which originally supplied a wall mounted light fitting powered by the light switch. I wish to change to led strip lights as am building some shelves in this location.
In short I need to safely reduce from 240v to a supply the plasma and ongoing led strips can accommodate.
If it can handle 240V AC in, and supply 5V DC out, yes. You don’t have to supply the +5V to the USB C Connector. You can feed it in via the screw terminals.
