PM524 - Dual Mic
Hi there!, I was wondering if you can help on an issue here. I was able to install as input device the Mic (adau7002). The Clip record script works fine. Then I’ve installed the AlexaPi software in order to use it with the microphone. But I can’t get it work properly. My question is, should I enable somehow the microphone or it’s already enable (active) by default? -Seems that the mic only works when I execute the arecord script-
Thank you.
