Is there a way to flash the Presto via a Chromebook? I do not have a Mac that can recognize the device, but I do have a Chromebook with a linux partition. I was able to use Thonny to move files around but not flash the drive. If not what files can I copy back to the Presto to get to the default install.
Maybe a better question is I just want the orginal main.py. I modified it for a project but I want to just go back to default. Where do I find just the default main.py? If I want to run an example on boot like the clock do I just add that code to main.py?
You can find the original example files on GitHub:
Also, I don’t have a Chromebook but I would expect flashing to work since it just requires to put the presto into bootloader mode and then move the uf2 file into it.
Instructions here:
