I set up my touchphat a while ago and it works well on the whole. The only issue I have with it is the Python script that works with it. My script switches on and off my amplifier over Telnet and this works well most of the time. But if for some reason there is a problem with the amp…it could be that the telnet session hadn’t closed properly or that the amp is powered off for some reason…then the script exits with an error.
Is there anyway I can add to the code in the script and tell it to carry on even if there is a problem connecting over telnet? Tell it to just ignore the issue. Otherwise I have to get my laptop, log into the touchphat pi and restart the script…which is obviously not ideal.
Here is my script:
#!/usr/bin/env python
import signal
import touchphat
import os
import telnetlib
from kodijson import Kodi
#from time import sleepmy_kodi = Kodi(‘http://192.168.0.8:8080/jsonrpc’)
tn = telnetlib.Telnet(‘192.168.0.2’)@touchphat.on_release([‘A’])
def handle_touch(event):
print(“Kitchen Amp Off”)
time.sleep(.1)tn.close()
time.sleep(.2)
tn.open(‘192.168.0.2’)
tn.write(“ST04OFF\r\n”)
tn.close()
time.sleep(.2)@touchphat.on_touch([‘A’])
print(“Kitchen Room Amp On”)
my_kodi.Settings.SetSettingValue({ “setting”:“audiooutput.audiodevice”,“value”:“ALSA:sysdefault:CARD=IQaudIODAC” })
time.sleep(.2)
tn.write(“ST04ASIG\r\n”)
tn.close()
time.sleep(.2)signal.pause()
And here is the error message I get when the script has ‘crashed’:
Exception in thread Thread-1:
File “/usr/lib/python2.7/threading.py”, line 801, in __bootstrap_inner
self.run()
File “/usr/lib/python2.7/dist-packages/cap1xxx.py”, line 231, in run
if self.todo() == False:
File “/usr/lib/python2.7/dist-packages/cap1xxx.py”, line 457, in _poll
self._handle_alert()
File “/usr/lib/python2.7/dist-packages/cap1xxx.py”, line 450, in _handle_alert
self._trigger_handler(x, inputs)
File “/usr/lib/python2.7/dist-packages/cap1xxx.py”, line 464, in _trigger_hand ler
self.handlers[event][channel](CapTouchEvent(channel, event, self.input_delta [channel]))
File “/usr/lib/python2.7/dist-packages/touchphat/init.py”, line 103, in _h andle_press
_on_presschannel
File “kitchen.py”, line 72, in handle_touch
my_kodi.Settings.SetSettingValue({ “setting”:“audiooutput.audiodevice”,“valu e”:“ALSA:sysdefault:CARD=IQaudIODAC” })
File “/home/pi/.local/lib/python2.7/site-packages/kodijson/kodijson.py”, line 121, in hook
return self.kodi.execute(kodimethod, *args, **kwargs)
File “/home/pi/.local/lib/python2.7/site-packages/kodijson/kodijson.py”, line 71, in execute
auth=(self.username, self.password))
File “/home/pi/.local/lib/python2.7/site-packages/requests/api.py”, line 112, in post
return request(‘post’, url, data=data, json=json, **kwargs)
File “/home/pi/.local/lib/python2.7/site-packages/requests/api.py”, line 58, i n request
return session.request(method=method, url=url, **kwargs)
File “/home/pi/.local/lib/python2.7/site-packages/requests/sessions.py”, line 508, in request
resp = self.send(prep, **send_kwargs)
File “/home/pi/.local/lib/python2.7/site-packages/requests/sessions.py”, line 618, in send
r = adapter.send(request, **kwargs)
File “/home/pi/.local/lib/python2.7/site-packages/requests/adapters.py”, line 508, in send
raise ConnectionError(e, request=request)
ConnectionError: HTTPConnectionPool(host=‘192.168.0.8’, port=8080): Max retries exceeded with url: /jsonrpc (Caused by NewConnectionError(‘<urllib3.connection.H TTPConnection object at 0xb5a97790>: Failed to establish a new connection: [Errn o 111] Connection refused’,))^CTraceback (most recent call last):
File “kitchen.py”, line 149, in
signal.pause()
