Qw/ST Pad & Pimoroni Explorer
I’ve just received my Qw/ST Pad (I2C Game Controller), have installed the library on a Pico plus 2 and Pimoroni Explorer. I’ve been trying to run the pad_detect.py program on both boards. The Pico plus 2 finds the Pad but the Explorer board does not.
Am I missing something?
The pad_detect.py has hardwired I2C-pins (4 and 5). The Explorer uses other pins (20 and 21).
Tried swapping sda and scl pin values in program from 4 & 5 to 20 and 21 but still no joy on the Explorer. I’m running the latest verson of the pimoroni .uf2.
Will the pad work with the Pimoroni Explorer? If so, how?
It should work with any Qw/ST board (if you give it the correct I2C pins).
Does it show up on an I2C scan?
import machine
sda=machine.Pin(20)
scl=machine.Pin(21)
i2c=machine.I2C(0,sda=sda, scl=scl, freq=400000)
print('Scan i2c bus...')
devices = i2c.scan()
if len(devices) == 0:
    print("No i2c device !")
else:
    print('i2c devices found:',len(devices))
for device in devices:
    print("Decimal address: ",device," | Hexa address: ",hex(device))
This version of read_all.py is working
# read_all.py for Pimoroni Explorer
from machine import I2C
from explorer import display, i2c, button_z, button_x, button_y, BLACK, WHITE, GREEN, RED, BLUE, YELLOW, CYAN
from qwstpad import QwSTPad
How to read all of the buttons on QwSTPad.
SLEEP = 0.1                                 # The time between each reading of the buttons
# Attempt to create the I2C instance and pass that to the QwSTPad
try:
    qwstpad = QwSTPad(i2c, 0x21)
except OSError:
    print("QwSTPad: Not Connected ... Exiting")
    raise SystemExit
print("QwSTPad: Connected ... Starting")
# Wrap the code in a try block, to catch any exceptions (including KeyboardInterrupt)
try:
    # Loop forever
        # Read all the buttons from the qwstpad and print them out
        buttons = qwstpad.read_buttons()
        for key, value in buttons.items():
            print(f"{key} = {value:n}", end=", ")
        print()
        time.sleep(SLEEP)
# Handle the QwSTPad being disconnected unexpectedly
except OSError:
    print("QwSTPad: Disconnected .. Exiting")
    qwstpad = None
# Turn off all four LEDs if there is still a QwSTPad
finally:
    if qwstpad is not None:
        qwstpad.clear_leds()
pad_detect.py . This also finds the sensor stick if fitted = addr 0x23 CLASH
# pad_detect for Pimoroni Explorer
from qwstpad import ADDRESSES, QwSTPad
How to detect multiple QwSTPads and handle their unexpected connection and disconnection.
# Constants
#I2C_PINS = {"id": 0, "sda": 20, "scl": 21}    # The I2C pins the QwSTPads are connected to (4 and 5 originally)
SLEEP = 0.2                                 # The time between each check of connected pads
# Variables
#i2c = I2C(**I2C_PINS)                       # The I2C instance to pass to all QwSTPads
pads = {}                                   # The dictionary to store QwSTPad objects
active = False                              # The state to set the controlled LEDs to
try:
        print("QwSTPads: ", end="")
        # Go through each valid QwSTPad address
        for addr in ADDRESSES:
            # Is the pad already registered?
            if addr in pads:
                try:
                    # Do some action to confirm it is still connected
                    if active:
                        pads[addr].set_leds(pads[addr].address_code())
                    else:
                        pads[addr].clear_leds()
                except OSError:
                    # If that fails, unregister it
                    del pads[addr]
            # The pad is not registered
            else:
                try:
                    # Attempt to connect to and register it
                    pads[addr] = QwSTPad(i2c, addr)
                except OSError:
                    # If that fails, carry on
                    pass
            # Print out the connected state of the current pad
            print(f"{hex(addr)}" if addr in pads else "----", end=" ")
        print()
        # Toggle the LED state for next time
        active = not active
        time.sleep(SLEEP)
# Turn off the LEDs of any connected QwSTPads
finally:
    for addr in pads:
        try:
        except OSError:
            pass
Aha, I forgot the Explorer library set up I2C for you. I wonder if trying to set it up twice was causing shenanigans?
The new maze game is harder to fix.
@Tonygo2 , the i2c address being used catches me out quite regularly. As soon as I see a “not found” I start looking at what bus pins are being used by what device I’m using. I applaud you for sticking with it. Been there done that.
When I can I do something like this
i2c = PimoroniI2C(sda=(20), scl=(21))
And then save the working file to a folder for said device.
Here is the new maze game working on the Pimoroni Explorer
#random_maze for Pimoroni Explorer
import gc
import random
from collections import namedtuple
#from picographics import DISPLAY_PICO_DISPLAY_2 as DISPLAY
from picographics import PEN_RGB565, PicoGraphics, RGB_to_RGB565
A single player QwSTPad game demo. Navigate a set of mazes from the start (red) to the goal (green).
Mazes get bigger / harder with each increase in level.
Makes use of 1 QwSTPad and a Pico Display Pack 2.0 / 2.8.
Controls:
* U = Move Forward
* D = Move Backward
* R = Move Right
* L = Move left
* + = Continue (once the current level is complete)
# General Constants
#I2C_PINS = {"id": 0, "sda": 4, "scl": 5}    # The I2C pins the QwSTPad is connected to
#I2C_ADDRESS = ADDRESSES[0]                  # The I2C address of the connected QwSTPad
BRIGHTNESS = 1.0                            # The brightness of the LCD backlight (from 0.0 to 1.0)
# Colour Constants (RGB565)
WHITE = RGB_to_RGB565(255, 255, 255)
BLACK = RGB_to_RGB565(0, 0, 0)
RED = RGB_to_RGB565(255, 0, 0)
GREEN = RGB_to_RGB565(0, 255, 0)
PLAYER = RGB_to_RGB565(227, 231, 110)
WALL = RGB_to_RGB565(127, 125, 244)
BACKGROUND = RGB_to_RGB565(60, 57, 169)
PATH = RGB_to_RGB565((227 + 60) // 2, (231 + 57) // 2, (110 + 169) // 2)
# Gameplay Constants
Position = namedtuple("Position", ("x", "y"))
MIN_MAZE_WIDTH = 2
MAX_MAZE_WIDTH = 5
MIN_MAZE_HEIGHT = 2
MAX_MAZE_HEIGHT = 5
WALL_SHADOW = 2
WALL_GAP = 1
TEXT_SHADOW = 2
MOVEMENT_SLEEP = 0.1
DIFFICULT_SCALE = 0.5
# Variables
display = PicoGraphics(display=DISPLAY,         # The PicoGraphics instance used for drawing to the display
                       pen_type=PEN_RGB565)     # It uses 16 bit (RGB565) colours
#i2c = I2C(**I2C_PINS)                           # The I2C instance to pass to the QwSTPad
complete = False                                # Has the game been completed?
level = 0                                       # The current "level" the player is on (affects difficulty)
# Get the width and height from the display
# Classes
class Cell:
    def __init__(self, x, y):
        self.x = x
        self.y = y
        self.bottom = True
        self.right = True
        self.visited = False
    @staticmethod
    def remove_walls(current, next):
        dx, dy = current.x - next.x, current.y - next.y
        if dx == 1:
            next.right = False
        if dx == -1:
            current.right = False
        if dy == 1:
            next.bottom = False
        if dy == -1:
            current.bottom = False
class MazeBuilder:
    def __init__(self):
        self.width = 0
        self.height = 0
        self.cell_grid = []
        self.maze = []
    def build(self, width, height):
        if width <= 0:
            raise ValueError("width out of range. Expected greater than 0")
        if height <= 0:
            raise ValueError("height out of range. Expected greater than 0")
        self.width = width
        self.height = height
        # Set the starting cell to the centre
        cx = (self.width - 1) // 2
        cy = (self.height - 1) // 2
        gc.collect()
        # Create a grid of cells for building a maze
        self.cell_grid = [[Cell(x, y) for y in range(self.height)] for x in range(self.width)]
        cell_stack = []
        # Retrieve the starting cell and mark it as visited
        current = self.cell_grid[cx][cy]
        current.visited = True
        # Loop until every cell has been visited
            next = self.choose_neighbour(current)
            # Was a valid neighbour found?
            if next is not None:
                # Move to the next cell, removing walls in the process
                next.visited = True
                cell_stack.append(current)
                Cell.remove_walls(current, next)
                current = next
            # No valid neighbour. Backtrack to a previous cell
            elif len(cell_stack) > 0:
                current = cell_stack.pop()
            # No previous cells, so exit
            else:
                break
        gc.collect()
        # Use the cell grid to create a maze grid of 0's and 1s
        self.maze = []
        row = [1]
        for x in range(0, self.width):
            row.append(1)
            row.append(1)
        self.maze.append(row)
        for y in range(0, self.height):
            row = [1]
                row.append(0)
                row.append(1 if self.cell_grid[x][y].right else 0)
            row = [1]
                row.append(1 if self.cell_grid[x][y].bottom else 0)
                row.append(1)
        self.cell_grid.clear()
        gc.collect()
        self.grid_columns = (self.width * 2 + 1)
        self.grid_rows = (self.height * 2 + 1)
    def choose_neighbour(self, current):
        unvisited = []
        for dx in range(-1, 2, 2):
            x = current.x + dx
            if x >= 0 and x < self.width and not self.cell_grid[x][current.y].visited:
                unvisited.append((x, current.y))
        for dy in range(-1, 2, 2):
            y = current.y + dy
            if y >= 0 and y < self.height and not self.cell_grid[current.x][y].visited:
                unvisited.append((current.x, y))
        if len(unvisited) > 0:
            x, y = random.choice(unvisited)
            return self.cell_grid[x][y]
        return None
    def maze_width(self):
        return (self.width * 2) + 1
    def maze_height(self):
        return (self.height * 2) + 1
    def draw(self, display):
        # Draw the maze we have built. Each '1' in the array represents a wall
        for row in range(self.grid_rows):
            for col in range(self.grid_columns):
                # Calculate the screen coordinates
                x = (col * wall_separation) + offset_x
                y = (row * wall_separation) + offset_y
                if self.maze[row][col] == 1:
                    # Draw a wall shadow
                    display.set_pen(BLACK)
                    display.rectangle(x + WALL_SHADOW, y + WALL_SHADOW, wall_size, wall_size)
                    # Draw a wall top
                    display.set_pen(WALL)
                    display.rectangle(x, y, wall_size, wall_size)
                if self.maze[row][col] == 2:
                    # Draw the player path
                    display.set_pen(PATH)
class Player(object):
    def __init__(self, x, y, colour, pad):
        self.x = x
        self.y = y
        self.colour = colour
        self.pad = pad
    def position(self, x, y):
        self.x = x
        self.y = y
    def update(self, maze):
        # Read the player's gamepad
        button = self.pad.read_buttons()
        if button['L'] and maze[self.y][self.x - 1] != 1:
            self.x -= 1
            time.sleep(MOVEMENT_SLEEP)
        elif button['R'] and maze[self.y][self.x + 1] != 1:
            self.x += 1
        elif button['U'] and maze[self.y - 1][self.x] != 1:
            self.y -= 1
        elif button['D'] and maze[self.y + 1][self.x] != 1:
            self.y += 1
        maze[self.y][self.x] = 2
        display.set_pen(self.colour)
        display.rectangle(self.x * wall_separation + offset_x,
                          self.y * wall_separation + offset_y,
def build_maze():
    global wall_separation
    global wall_size
    global offset_x
    global offset_y
    global start
    global goal
    difficulty = int(level * DIFFICULT_SCALE)
    width = random.randrange(MIN_MAZE_WIDTH, MAX_MAZE_WIDTH)
    height = random.randrange(MIN_MAZE_HEIGHT, MAX_MAZE_HEIGHT)
    builder.build(width + difficulty, height + difficulty)
    wall_separation = min(HEIGHT // builder.grid_rows,
                          WIDTH // builder.grid_columns)
    wall_size = wall_separation - WALL_GAP
    offset_x = (WIDTH - (builder.grid_columns * wall_separation) + WALL_GAP) // 2
    offset_y = (HEIGHT - (builder.grid_rows * wall_separation) + WALL_GAP) // 2
    start = Position(1, builder.grid_rows - 2)
    goal = Position(builder.grid_columns - 2, 1)
# Create the maze builder and build the first maze and put
builder = MazeBuilder()
build_maze()
# Create the player object if a QwSTPad is connected
try:
    player = Player(*start, PLAYER, QwSTPad(i2c, 0x21))
except OSError:
    raise SystemExit
# Turn on the display
display.set_backlight(BRIGHTNESS)
try:
    # Loop forever
        if not complete:
            # Update the player's position in the maze
            player.update(builder.maze)
            # Check if any player has reached the goal position
            if player.x == goal.x and player.y == goal.y:
                complete = True
        else:
            # Check for the player wanting to continue
            if player.pad.read_buttons()['+']:
                complete = False
                level += 1
                build_maze()
                player.position(*start)
        # Clear the screen to the background colour
        display.set_pen(BACKGROUND)
        display.clear()
        # Draw the maze walls
        builder.draw(display)
        # Draw the start location square
        display.set_pen(RED)
        display.rectangle(start.x * wall_separation + offset_x,
                          start.y * wall_separation + offset_y,
        # Draw the goal location square
        display.set_pen(GREEN)
        display.rectangle(goal.x * wall_separation + offset_x,
                          goal.y * wall_separation + offset_y,
        # Draw the player
        player.draw(display)
        # Display the level
        display.text(f"Lvl: {level}", 2 + TEXT_SHADOW, 2 + TEXT_SHADOW, WIDTH, 1)
        display.set_pen(WHITE)
        display.text(f"Lvl: {level}", 2, 2, WIDTH, 1)
        if complete:
            # Draw banner shadow
            display.rectangle(4, 94, WIDTH, 50)
            # Draw banner
            display.set_pen(PLAYER)
            display.rectangle(0, 90, WIDTH, 50)
            # Draw text shadow
            display.text("Maze Complete!", WIDTH // 6 + TEXT_SHADOW, 96 + TEXT_SHADOW, WIDTH, 3)
            display.text("Press + to continue", WIDTH // 6 + 10 + TEXT_SHADOW, 120 + TEXT_SHADOW, WIDTH, 2)
            # Draw text
            display.text("Maze Complete!", WIDTH // 6, 96, WIDTH, 3)
            display.text("Press + to continue", WIDTH // 6 + 10, 120, WIDTH, 2)
        # Update the screen
        display.update()
except OSError:
# Turn off the LEDs of the connected QwSTPad
finally:
    try:
        player.pad.clear_leds()
    except OSError:
        pass
