I’ve spent the morning coding my Pimoroni Explorer with a Qw/ST Pad fitted trying out the buttons with a some Christmas themed graphics. My normal method is to add a procedure to the code, test it and slowly build up the full program. I’ve found that it crashes every 10 minutes or so when the RUN button is clicked in Thonny and I have to press the reset button or unplug the USB cable to get it going again. The code then runs perfectly.
Has anyone else been experiencing a similar problem?
Here is the code if anyone is interested.
# Pimoroni Explorer, with qwstpad
# Demo with graphics, buttons and LEDs
# Uses button UDLR as NSEW and XYAB for stars
# Button '+' bauble
# Halt with '-' button
from machine import I2C
from explorer import display, i2c, button_z, button_x, button_y, BLACK, WHITE, GREEN, RED, BLUE, YELLOW, CYAN, MAGENTA
from qwstpad import QwSTPad
from random import randint
display.set_font("bitmap6")
# Connect single default I2C address QwSTPad
try:
qwstpad = QwSTPad(i2c, 0x21)
except OSError:
print("QwSTPad: Not Connected ... Exiting")
raise SystemExit
print("QwSTPad: Connected ... Starting")
# (xx, yy) point of arrowhead sz is size = point to centre of base
def north(xx,yy,sz,col):
s2 = int(sz*0.5773) # tan30
display.set_pen(col)
display.triangle(xx,yy,xx-s2,yy+sz, xx+s2,yy+sz)
def south(xx,yy,sz,col):
s2 = int(sz*0.5773)
display.triangle(xx,yy,xx-s2,yy-sz,xx+s2,yy-sz)
def west(xx,yy,sz,col):
s2 = int(sz*0.5773)
display.triangle(xx,yy,xx+sz,yy-s2,xx+sz,yy+s2)
def east(xx,yy,sz,col):
s2 = int(sz*0.5773)
display.triangle(xx,yy,xx-sz,yy+s2,xx-sz,yy-s2)
# (xx, yy) centre of star
def star1(xx,yy,size,col):
north(xx,yy,size,col)
south(xx,yy+int(2.7*size/2),size,col)
def star2(xx,yy,size,col):
west(xx,yy,size,col)
east(xx+int(2.7*size/2),yy,size,col)
def clean():
display.set_layer(0)
display.set_pen(BLACK)
display.clear()
display.set_layer(1)
display.clear()
clean()
display.set_font("bitmap8") # Lower-case font
display.set_pen(YELLOW)
display.text("Pimoroni Explorer, qwstPad, buttons, LEDs, graphical stars and pointers",5,40,310,3)
display.set_pen(BLUE)
display.text("Tony Goodhew - 7 Dec 2024",30,200,310,2)
display.update()
time.sleep(4)
clean()
colours = [BLACK, WHITE, GREEN, RED, BLUE, YELLOW, CYAN, MAGENTA]
SLEEP = 0.0 # The time between each reading of the buttons
# Wrap the code in a try block, to catch any exceptions (including KeyboardInterrupt)
try:
# Loop forever
buttons = qwstpad.read_buttons()
while buttons["-"] == False: # HALT loop with button'-'
size = 70
clean()
leds = 0
# Read all the buttons from the qwstpad
U = buttons["U"]
if U == True:
north(159,0,size,RED)
leds = leds + 1
D = buttons["D"]
if D == True:
south(159,239,size,RED)
leds = leds + 2
L = buttons["L"]
if L == True:
west(0,119,size,RED)
leds = leds + 4
R = buttons["R"]
if R == True:
east(319,119,size,RED)
leds = leds + 8
X = buttons["X"] # STAR1
if X == True:
star1(159,119-int(2.7*size/4),size,BLUE)
leds = 15
Y = buttons["Y"] # STAR2
if Y == True:
star2(159-int(2.7*size/4),119,size,CYAN)
leds = 6
A = buttons["A"] # STAR2
if A == True:
star1(159,119-int(2.7*size/4),size,MAGENTA)
star2(159-int(2.7*size/4),119,size,MAGENTA)
leds = 9
B = buttons["B"] # Multiple stars
# If SLEEP equals zero persentence of vision
# makes multiple stars appear at once
# The persistence of vision in a normal human eye is 1/16 sec
if B == True:
cr = colours[randint(1,7)]
xr = randint(0,319)
yr = randint(0,239)
size = randint(10,70)
q =randint(1,11)
if q <= 4:
star1(xr,yr-int(2.7*size/4),size,cr)
elif q >= 8:
star2(xr-int(2.7*size/4),yr,size,cr)
else:
leds = 9
P = buttons["+"] # Multiple stars
if P == True:
size = 90
display.set_pen(RED)
display.circle(159,140,80)
star1(159,140-int(2.7*size/4),size,GREEN)
star2(159-int(2.7*size/4),140,size,GREEN)
size = 55
star1(159,140-int(2.7*size/4),size,YELLOW)
star2(159-int(2.7*size/4),140,size,YELLOW)
size = 35
star1(159,140-int(2.7*size/4),size,WHITE)
star2(159-int(2.7*size/4),140,size,WHITE)
size = 45
star2(159-int(2.7*size/4),140,size,BLUE)
display.circle(159,60,15)
display.rectangle(145,40,30,10)
display.line(159,50,159,0)
display.text("Merry",75,20,310,3)
display.text("Christmas",170,20,100,3)
size = 70
leds = 5
qwstpad.set_leds(leds)
display.update()
time.sleep(SLEEP)
display.text("HALTED",30,110,300,5)
display.update()
time.sleep(3)
clean()
display.update()
# Handle the QwSTPad being disconnected unexpectedly
except OSError:
print("QwSTPad: Disconnected .. Exiting")
qwstpad = None
# Turn off all four LEDs if there is still a QwSTPad
finally:
if qwstpad is not None:
qwstpad.clear_leds()
It is interesting to note that the multiple stars routine runs so fast that although only one star is displayed at a time before the display is cleared and another random star drawn that persistence of vision tricks us into thinking at 5 or 6 are shown at a time. I did not expect this. All credit to the MicroPython team and Gadgetoid’s Picographics to get things running so rapidily.
