Hi, I have just bought 2 of the new Raspi Cameras, V2. Yey.
I fitted the standard camera into a Raspberry Pi Camera Mount that I purchased from you a couple of years ago. The camera does not fit into the recess. The hole is to small. (In both my Pi Camera Mounts.)
I was under the impression from the Foundation announcement post that the camera was a drop-in replacement, however this appears not to be so.
I did secure the camera to the case using the screws and nuts, however this induced a slight flex in the camera board,which I didn’t notice until the camera produced slightly out of focus images. When I loosened the screws on the mount the image was fine, although not firmly held and not a long term solution.
(BTW the images are v. good in comparison to the old camera, so I would recommend the update.)
I have a couple of questions:
Should the Pi Camera V2 fit in the existing case?
Are you planning a new version of the Pi Camera Mount anytime soon?
Do you need any more info, e.g. Photo?
Any suggestions?
