Hi, I have been trying to get the RM2 wireless breakout to connect to Wifi networks with the Pico Lipo2 but have had no success, using this example code:
This example will scan for wireless networks and attempt to connect
to the one specified in secrets.py.
If you’re using a Pico LiPo 2 you’ll need an RM2 breakout and an 8-pin JST-SH cable.
Grab them here: RM2 Wireless & Bluetooth Breakout (SP/CE)
Don’t forget to edit secrets.py and add your SSID and PASSWORD.
import network
import binascii
from secrets import WIFI_SSID, WIFI_PASSWORD
Create a table of names for connection states
CONNECTION_STATES = {v : k[5:] for k, v in network.dict.items() if k.startswith(“STAT_”)}
CONNECTION_TIMEOUT = 10
net = network.WLAN(network.STA_IF)
net.active(False)
net.active(True)
print(“\nScanning for WiFi networks.”)
results =
while not results:
print(“Scanning…”)
results = net.scan()
padding = max(len(r[0]) for r in results) + 1
print(“\nFound WiFi networks:”)
print(f"{‘SSID’:{padding}s} {‘BSSID’:17s} CH dB Auth")
for (ssid, bssid, channel, rssi, auth_mode, _) in results:
Auth mode is a bitfield,
see
auth_modes = [mode for b, mode in ((1, “WEP”), (2, “WPA”), (4, “WPA2”)) if auth_mode & b] or [“open”]
bssid = binascii.hexlify(bssid, ":").decode()
print(f"{ssid:{padding}s} {bssid} {channel:2d} {rssi: 2d} {'/'.join(auth_modes)}")
print(f"\nConnecting to {WIFI_SSID}.")
net.connect(WIFI_SSID, WIFI_PASSWORD)
t_start = time.time()
status = net.status()
print(f"Status: {CONNECTION_STATES.get(status, status)}")
if status in (network.STAT_GOT_IP, network.STAT_CONNECT_FAIL):
break
if time.time() - t_start > CONNECTION_TIMEOUT:
print(f"Timed out after {CONNECTION_TIMEOUT} seconds…")
break
time.sleep(1.0)
and updating the details in secrets will result in the board scanning successfully but failing to connect to any networks. I have tried on two separate networks and have even made one network have no authentication but it still fails to connect. What am I doing wrong?
