one digital output to drive a sold state relay.
What modules would you recommend.
The modbus could be a usb adapter but the disadvantage is that it takes up additional space because it sticks out at the end.
thanks henning
Thanks - we will use type K.
Problem as I see is to build those functions up to work at the same time - the usb485 is ok on its own because it uses the USB, but the thermocouples we need two and we need to fan-out one DIO. Do you have a module which can do that? Of course one can solder wires between boards but this is too cumbersome we will need to make 50pcs.
