I noticed the rpi5 NVMe Base Duo has 2 power pins (5V/GND),do these pins allow supplying additional power to the board if needed?
I have the same question. Did you ever get an answer to it from somewhere?
For very specific questions you should write directly to support. Most of the Pimoroni products have a schematic, this one does not. Judging from the images, these “pins” look more like test points. The normal base in contrast has a footprint which seems like it is made for a normal JST-PH2 SMD connector.
