I am having an issue similar to this post - Rpi 5 with Pimoroni NVMe Base poor performance. I recently received 4 of the Pimoroni NVMe bases, and assembled all 4 of them with my Raspberry Pi 5s for a cluster build. I noticed that when I am booting off of the NVMe - I get terrible boot times and consistent I/O errors in syslog. And the system seems to hiccup constantly, taking a long time to respond to commands.
Part Details
- 4xRaspberry Pi 5 8gb w/ Active Cooler
- 4xPower Supplies - CanaKit 45W USB-C Power Supply with PD for Raspberry Pi 5 (27W @ 5A)
- 4xPimoroni NVMe Base
- 4xNVMe’s - Team MP33
Running Raspberry Pi OS Lite (64 bit) - Bookworm
Config (current)
pi@node1:~ $ rpi-eeprom-config
[all]
BOOT_UART=1
BOOT_ORDER=0xf146
POWER_OFF_ON_HALT=0
PCIE_PROBE=1
pi@node1:~ $ tail -2 /boot/firmware/config.txt
[all]
dtparam=nvme
I have tried with dtparam=pciex1 with and without the addition of dtparam=pciex1_gen=3, but all yield the same results.
Errors / Logs
Boot Times
pi@node1:~ $ systemd-analyze
Startup finished in 34.026s (kernel) + 43.463s (userspace) = 1min 17.489s
multi-user.target reached after 43.451s in userspace.
pi@node1:~ $ systemd-analyze blame
34.944s dev-nvme0n1p2.device
7.080s NetworkManager-wait-online.service
4.526s man-db.service
2.230s bthelper@hci0.service
2.226s dpkg-db-backup.service
2.157s logrotate.service
2.142s systemd-tmpfiles-clean.service
1.113s raspi-config.service
216ms sys-kernel-tracing.mount
Syslog Errors
Feb 23 06:40:06 node1 kernel: nvme nvme0: I/O 632 (I/O Cmd) QID 3 timeout, aborting
Feb 23 06:40:08 node1 kernel: nvme nvme0: I/O 704 (I/O Cmd) QID 4 timeout, aborting
Feb 23 06:40:08 node1 kernel: nvme nvme0: I/O 705 (I/O Cmd) QID 4 timeout, aborting
Feb 23 06:40:08 node1 kernel: nvme nvme0: I/O 706 (I/O Cmd) QID 4 timeout, aborting
Feb 23 06:40:08 node1 kernel: nvme nvme0: I/O 707 (I/O Cmd) QID 4 timeout, aborting
Feb 23 06:40:08 node1 kernel: nvme nvme0: I/O 708 (I/O Cmd) QID 4 timeout, aborting
Feb 23 06:40:08 node1 kernel: nvme nvme0: I/O 709 (I/O Cmd) QID 4 timeout, aborting
Feb 23 06:40:08 node1 kernel: nvme nvme0: I/O 710 (I/O Cmd) QID 4 timeout, aborting
Feb 23 06:40:08 node1 kernel: nvme nvme0: Abort status: 0x0
Troubleshooting
I have tried:
- all logical combinations of the boot config with dtparam
- updating firmware with
rpi-update(on node1 only) - updating packages with apt-get update / apt-get upgrade
- setting the boot order manually with
rpi-eeprom-config --edit - setting the boot order via
raspi-config
Later today I plan on taking the top node off and re-seating the ribbon cable and the NVMe, but I don’t believe this is the issue as I am experiencing this on all 4 of my nodes (and I would like to think I didn’t screw up 4 times).
Seeking advice for other things to try today to hopefully resolve this.
