Hi there,
I have a Problem with my Python script on my Raspberry Zero.
All worked fine, except the scoll-function at the end, the display is empty:
#!/usr/bin/env python
import datetime
import math
import subprocess
from microdotphat import write_string, show, scroll, set_decimal, set_pixel, clear
print("""Press Ctrl+C to exit.""")
scrolltext = subprocess.Popen(['mpc', 'current'], stdout=subprocess.PIPE).stdout.read().strip().decode('utf-8')
write_string(scrolltext, offset_x=0)
# Intro Sinuswelle fuer 10Sekunden
t1 = time.time() + 10
while time.time() < t1:
clear()
t = time.time() * 10
for x in range(45):
y = int((math.sin(t + (x/2.5)) + 1) * 3.5)
set_pixel(x, y, 1)
show()
time.sleep(0.01)
# Zeit fuer 10Sekunden
t2 = time.time() + 10
while time.time() < t2:
clear()
t = datetime.datetime.now()
if t.second % 2 == 0:
set_decimal(3, 1)
else:
set_decimal(3, 0)
write_string(t.strftime(' ''%H%M'), kerning=False)
show()
time.sleep(0.05)
# Datum fuer 4Sekunden
t3 = time.time() + 4
while time.time() < t3:
clear()
write_string(t.strftime('%d%m%y'), kerning=False)
set_decimal(2, 1)
set_decimal(4, 1)
show()
time.sleep(0.05)
# Interpret fuer 4 Sekunden
t4 = time.time() + 4
while time.time() < t4:
clear()
scroll()
show()
time.sleep(0.05)
BUT, a script just with the basic function will work:
import subprocess
from microdotphat import write_string, scroll, show
scroll()
show()
time.sleep(0.05)
If I replaced the scroll() with somethink like set_pixel(x, y, 1) for example - it works. I dont know why the scroll function make me so much trouble.
