Hi there, this is my first RPI project and I’m having issues getting the scroll phat working :/
I’m using the hammerless solder kit and i’ve made sure all the connections are tight.
The following code:
#!/usr/bin/env python
import scrollphat
import math
import sys
i = 0
buf = [0] * 11
scrollphat.set_brightness(20)
    try:
        for x in range(0, 11):
            y = (math.sin((i + (x * 10)) / 10.0) + 1) # Produces range from 0 to 2
            y *= 2.5 # Scale to 0 to 5
            buf[x] = 1 << int(y)
        scrollphat.set_buffer(buf)
        scrollphat.update()
        time.sleep(0.005)
        i += 1
    except KeyboardInterrupt:
        scrollphat.clear()
        sys.exit(-1)
running the above yields:
File "test.py", line 3, in <module>
    import scrollphat
File "build/bdist.linux-armv6l/egg/scrollphat/__init__.py", line 20, in <module>
File "build/bdist.linux-armv6l/egg/scrollphat/IS31FL3730.py", line 21, in __init__
File "build/bdist.linux-armv6l/egg/scrollphat/IS31FL3730.py", line 62, in set_mode
IOError: [Errno 121] Remote I/O error
My scroll phat has i2c addr: 0x74 on the back of the board, also running :
pi@scrollpi:~ $ i2cdetect -y 1
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- 74 -- -- --
so it looks like it can ‘see’ the board, but not communicate with it…
any ideas would be very welcome…
