I am using Raspbian Stretch with Raspberry Pi 3 and skywriter library is 0.0.7
File “test.py”, line 10, in
@skywriter.move()
File “/usr/local/lib/python3.5/dist-packages/skywriter-0.0.7-py3.5.egg/skywriter.py”, line 431, in move
File “/usr/local/lib/python3.5/dist-packages/skywriter-0.0.7-py3.5.egg/skywriter.py”, line 484, in setup
The handler will receive a rotation delta in degrees
Error in atexit._run_exitfuncs:
File “/usr/local/lib/python3.5/dist-packages/skywriter-0.0.7-py3.5.egg/skywriter.py”, line 457, in _exit
A sort of grab-and-throw-away-garbage above the Skywriter
File “/usr/local/lib/python3.5/dist-packages/skywriter-0.0.7-py3.5.egg/skywriter.py”, line 315, in _stop_poll
Assert transfer line low to ensure
AttributeError: ‘NoneType’ object has no attribute ‘stop’
This is my output for i2cdetect -y 1
Can someone suggest how to fix this.
