Am I the first person to connect this LED driver board to an Arduino ? - I can’t see any mention of the following issue here or on the GIThub site.
I finally got round to wiring up this board after Christmas and found that only the first 8 channels were working.
A quick check of the library code showed up two typo’s that appear to have slipped through onto the net.
The constant SN3218_CH_ALL , which should turn on all 18 channels ,appears in the header file as 3FFF ( 14 ones in binary ) , but it should be 3FFFF (18 ones).
Secondly , the “enableLEDs” function has three “writeReg” commands for switching on the 3 blocks of drivers, but the
second and third address the same register - “SN3218_CMD_ENABLE_LEDS + 1” . The third one should address the next
register “SN3218_CMD_ENABLE_LEDS + 2”.
After making those changes , the full 18 channels work fine.
