Hi there!
I have problems getting started with the explorerphat.
This is what i get:
import explorerhat
File “”, line 1, in
File “/usr/lib/python3.5/site-packages/explorerhat/init.py”, line 692, in
_cap1208 = Cap1208()
File “/usr/lib/python3.5/site-packages/cap1xxx.py”, line 275, in init
raise Exception(“Product ID {} not supported!”.format(self.product_id))
Exception: Product ID -5 not supported!
it looks like i2c is fine …
[root@bender matto]# i2cdetect -l
i2c-1 i2c 3f804000.i2c I2C adapter
[root@bender matto]# i2cdetect 1
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-1.
I will probe address range 0x03-0x77.
Continue? [Y/n] Y
00: – – – – – – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – – – – – – – 48 – – – – – – –
50: – – – – – – – – – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
Technical-reference.md says explorerphat s i2c address is 0x48 … ok
looking into “cap1xxx.py”:
here we have
DEFAULT_ADDR = 0x28
And it is checking for this
SMBus(1).read_byte_data(0x28, 0xFD)
which is not present… (Technical-reference.md → touch-buttons ?!?)
Am i doing something completly wrong here?
Greetings
matto
[edit]
i just replaced lines 691-695
try:
has_captouch = True
except IOError:
has_captouch = False
with
to bypass that check …
i still wonder why “except IOError:” does not catch the error …
[edit 2]:
The explorer-hat library tries to catch an IOError, with seems not to existi in python 3.5, so i changed it to a plain “Exception” which workes fine.
Greetings and thanks for this great pi-add-on!
matto
