Please can you tell me how much current can be drawn from the 3.3V output on the Tiny 2040 board?
Is there a schematic for the board?
Thanks,
Pifan
- Powered by RP2040
- ARM Cortex M0+ running at up to 133Mhz
- 264kB of SRAM
- USB-C connector for power, programming, and data transfer
- 8MB of QSPI flash supporting XiP
- User controllable RGB LED
- Twelve IO pins (including four 12-bit ADC channels)
- Switch for basic input (doubles up as DFU select on boot)
- On-board 3V3 regulator (max regulator current output 300mA)
- Input voltage range 3V - 5.5V
From AdaFruit
Ahoy - the Tiny 2040 schematic is now available on the shop page.
Thank you very much.
Pifan,
There is NO isolation diode on the 5 volt line.
