Hi, does anyone know how many LEDs can each channel of the TinyFX can power?
I have a total of 22 mono leds to plug into my TinyFX board (4 channels will have 4 leds, 2 will have 3).
Also with this number of leds would it be a good idea to disable the indicator leds on the board?
Andrew
Pimoroni lists a 1 A maximum for Tiny FX’s power input, so I wouldn’t assume that a given LED count is safe without knowing the LED type and current draw. Are these Pimoroni LED dots, another lighting kit, or bare LEDs, and what power supply are you using? Please share the LED part number or product page before changing the board or its indicator LEDs.
yes they are Pimoroni dots, but I miss-counted the number of leds, it is actually 24 as I used a couple the the tinyfx strips (so it will be 4 dots per channel from 22 jst connectors).
