Trilobot software errors
When I try to load the software from your “beginner friendly tutorial” link, everything appears to work until the “sudo ./install.sh” command. At this point I get the following errors:
E: Unable to locate package python-configparser
trilobot 0.0.2 Python Library: Installer
Installing for Python 2…
error: externally-managed-environment
Generating documentation.
Error: Failed to generate documentation.
I am using a pi 4B with a freshly installed 64 bit raspberry pi os ver. 2024-07-04
You may have better luck if you install Pi OS Legacy. The latest release, Bookworm, requires a Python Virtual Environment. If the installer isn’t written to take that into account you will get the
externally-managed-environment error.
Thank You Much.
That was the fix.
