Warning wall of code to follow. This is my Tufty BME280 code.
If you click the </> (Preformatted Text) option its the same as using code tags.
i2c = PimoroniI2C(sda=(4), scl=(5)) is what I use, and it is pins 4 and 5, not 20, 21.
You want to
get your info
display your info
display.update()
time.sleep
display.set_pen(black)
display.clear()
wash,rinse and repeat. ;)
import utime
import machine
import picographics
from picographics import PicoGraphics, DISPLAY_TUFTY_2040, PEN_RGB332
display = PicoGraphics(display=DISPLAY_TUFTY_2040, rotate=180, pen_type=PEN_RGB332)
display.set_backlight(1.0)
display.set_font("bitmap8")
from breakout_bme280 import BreakoutBME280
bme = BreakoutBME280(i2c)
from breakout_rtc import BreakoutRTC
from machine import RTC
RV3028 = BreakoutRTC(i2c)
rtc = BreakoutRTC(i2c)
if rtc.is_12_hour:
rtc.set_24_hour()
from machine import ADC, Pin
# set up the ADCs for measuring battery voltage
vbat_adc = ADC(29)
vref_adc = ADC(28)
vref_en = Pin(27)
vref_en.init(Pin.OUT)
vref_en.value(0)
usb_power = Pin(24, Pin.IN)
full_battery = 4.5
empty_battery = 2.5
# Setup light sensor
lux_pwr = Pin(27, Pin.OUT)
lux_pwr.value(1) # Turn on power!
lux = ADC(26)
from pimoroni import Button
button_a = Button(7, invert=False)
button_b = Button(8, invert=False)
button_c = Button(9, invert=False)
button_up = Button(22, invert=False)
button_down = Button(6, invert=False)
button_boot = Button(23, invert=True)
t_color = display.create_pen(0,255,0)
h_color = display.create_pen(0,255,0)
p_color = display.create_pen(0,255,0)
white = display.create_pen(255,255,255)
black = display.create_pen(0,0,0)
red = display.create_pen(255,0,0)
green = display.create_pen(0,255,0)
blue = display.create_pen(0,0,255)
yellow = display.create_pen(255,255,0)
orange = display.create_pen(255,140,0)
display.clear()
# converts the temperature into a description and pen colour
def describe_temperature(temperature):
global t_color
if temperature < -10:
description = "Very Cold"
t_color = white
elif -10 <= temperature <= 0:
description = "Cold"
t_color = blue
elif 0 < temperature <= 12:
description = "Cool"
t_color = yellow
elif 12 < temperature <= 16:
description = "OK"
t_color = green
elif 16 < temperature <= 24:
description = "Warm"
t_color = green
elif 24 < temperature <= 27:
description = "Hot"
t_color = orange
elif temperature > 27:
description = "Very Hot"
t_color = red
return description
# converts humidity into good/bad description and pen color
def describe_humidity(humidity):
global h_color
if humidity < 30:
description = "Low"
h_color = red
elif 30 <= humidity <= 60:
description = "OK"
h_color = green
elif 60 < humidity < 80:
description = "High"
h_color = yellow
elif humidity >= 80:
description = "Very High"
h_color = orange
return description
# converts pressure into barometer-type description and pen color
def describe_pressure(pressure):
global p_color
if pressure < 982:
description = "Very Low"
p_color = red
elif 982 <= pressure < 1004:
description = "Low"
p_color = yellow
elif 1004 <= pressure < 1026:
description = "OK"
p_color = green
elif 1026 <= pressure < 1048:
p_color = blue
elif pressure >= 1048:
p_color = orange
return description
# graphs current values for Temperature, Humidity and Pressure
def draw_graph(temp_value, press_value, humid_value):
scaled_temp = int(temperature * 10)
if scaled_temp <= 9:
scaled_temp =9
if scaled_temp >= 310:
scaled_temp =310
display.set_pen(yellow)
display.circle(9,98,9)
display.rectangle(9,89,116,19)
display.set_pen(green)
#display.rectangle(127,89,38,19)
display.rectangle(165,89,73,19)
display.set_pen(orange)
display.rectangle(240,89,28,19)
display.set_pen(red)
display.rectangle(270,89,44,19)
display.circle(310,98,9)
display.circle((scaled_temp),98,9)
display.set_pen(white)
display.circle((scaled_temp),98,5)
display.set_pen(t_color)
display.text(describe_temperature(temperature),130,52,scale=4)
scaled_humid = int(humidity * (320 / 100))
if scaled_humid <= 9:
scaled_humid =9
if scaled_humid >= 310:
scaled_humid =310
display.circle(9, 164, 9)
display.rectangle(12,155,82,19)
display.rectangle(96,155,94,19)
display.rectangle(192,155,62,19)
display.rectangle(256,155,55,19)
display.circle(310,164,9)
display.circle((scaled_humid),164,9)
display.circle((scaled_humid),164,5)
display.set_pen(h_color)
display.text(describe_humidity(humidity),130,117,scale=4)
scaled_press = int((pressuremb - 960) * 3)
if scaled_press <= 9:
scaled_press =9
if scaled_press >= 310:
scaled_press =310
describe_pressure(pressuremb)
display.circle(9, 230, 9)
display.rectangle(12,221,50,19)
display.rectangle(64,221,62,19)
display.rectangle(128,221,62,19)
display.set_pen(blue)
display.rectangle(192,221,62,19)
display.rectangle(256,221,52,19)
display.circle(310, 230, 9)
display.line(127,221,127,240)
display.circle((scaled_press),230,9)
display.circle((scaled_press),230,5)
display.set_pen(p_color)
display.text(describe_pressure(pressuremb),130,184,scale=4)
def describe_month(month):
month = rtc.get_month()
if month == 1:
description = "January"
elif month == 2:
description = "February"
elif month == 3:
description = "March"
elif month == 4:
description = "April"
elif month == 5:
description = "May"
elif month == 6:
description = "June"
elif month == 7:
description = "July"
elif month == 8:
description = "August"
elif month == 9:
description = "September"
elif month == 10:
description = "October"
elif month == 11:
description = "November"
elif month == 12:
description = "December"
return description
def describe_date(date):
date = rtc.get_date()
if date == 1:
description = "st"
elif date == 2:
description = "nd"
elif date == 3:
description = "rd"
elif date == 21:
description = "st"
elif date == 22:
description = "nd"
elif date == 23:
description = "rd"
elif date == 31:
description = "st"
else:
description = "th"
return description
start_time = utime.time()
time_elapsed = utime.time() - start_time
hours = rtc.get_hours()
minutes = rtc.get_minutes()
if rtc.read_periodic_update_interrupt_flag():
rtc.clear_periodic_update_interrupt_flag()
if rtc.update_time():
rtc_date = rtc.string_date()
rtc_time = rtc.string_time()
if button_a.is_pressed:
print ("Button A pressed")
utime.sleep(0.2)
if button_b.is_pressed:
if percentage >= 50:
display.text("Battery",0,9,scale=3)
display.text("{:0.2f}v".format(vbat),150,9,scale=3)
display.text("{:0.0f}%".format(percentage),265,9,scale=3)
elif 50 > percentage > 20:
display.text("Battery",0,9, scale=3)
elif percentage <= 20:
else:
if hours == 0:
display.text(f"{12}:{minutes:02} AM",5,9,scale=3)
elif 0 < hours < 10:
display.text(f"{hours:1}:{minutes:02} AM",5,9,scale=3)
elif 10 <= hours < 12:
display.text(f"{hours:2}:{minutes:02} AM",0,9,scale=3)
elif hours == 12:
display.text(f"{hours:2}:{minutes:02} PM",0,9,scale=3)
elif hours >12:
hours = hours - 12
if hours <10:
display.text(f"{hours:1}:{minutes:02} PM",5,9,scale=3)
elif hours == 12:
display.text(f"{describe_month(month)} {date}{describe_date(date)}",130,9,scale=3)
if button_c.is_pressed:
print ("Button C pressed")
utime.sleep(0.2)
if button_up.is_pressed:
utime.sleep(0.2)
if button_down.is_pressed:
display.set_backlight(0.4)
utime.sleep(0.2)
if button_boot.is_pressed:
print ("Button BOOT/USR pressed")
utime.sleep(0.2)
#reading = lux.read_u16()
#print (reading)
temperature, pressure, humidity = bme.read()
pressuremb = pressure / 100
temperature = round(temperature)
humidity = round(humidity)
pressure = round(pressure)
display.text("{:0.0f}°C" .format(temperature), 5, 52, scale=4)
display.text("{:0.0f}%".format(humidity), 5, 118, scale=4)
display.text("{:0.0f}mb".format(pressuremb), 5, 184, scale=4)
draw_graph(temperature, pressure, humidity)
vref_en.value(1)
vdd = 1.24 * (65535 / vref_adc.read_u16())
vbat = (
(vbat_adc.read_u16() / 65535) * 3 * vdd
vref_en.value(0)
# convert the raw ADC read into a voltage, and then a percentage
percentage = 100 * ((vbat - empty_battery) / (full_battery - empty_battery))
if percentage > 100:
percentage = 100
if percentage < 0:
percentage = 0
if time_elapsed < 0.5:
display.clear()
display.update()
utime.sleep(1)
else:
display.update()
utime.sleep(1)
display.clear()
utime.sleep(1)
