Tufty2040 - No display
Yes, I am very happy that everything is now working as it should.
This will now be a good starting point for me to learn MicroPython and get used to the RP2040.
Im new to all this but could you share the weather.py info, I’m trying to do the same thing and no luck.
I don’t know if @alphanumeric created their own weather.py file. Otherwise, you can check Pimoroni’s Github page for tufty2040’s examples.
This is my latest version, let me know what you think of it.
Pimoroni Tufty 2040
BME280
import utime
import picographics
from picographics import PicoGraphics, DISPLAY_TUFTY_2040, PEN_RGB332
display = PicoGraphics(display=DISPLAY_TUFTY_2040, rotate=180, pen_type=PEN_RGB332)
display.set_backlight(1.0)
display.set_font("bitmap8")
from breakout_bme280 import BreakoutBME280
i2c = PimoroniI2C(sda=(4), scl=(5))
bme = BreakoutBME280(i2c)
from machine import ADC, Pin
vbat_adc = ADC(29)
vref_adc = ADC(28)
vref_en = Pin(27)
vref_en.init(Pin.OUT)
vref_en.value(0)
usb_power = Pin(24, Pin.IN)
full_battery = 4.5
empty_battery = 2.8
from pimoroni import Button
button_a = Button(7, invert=False)
button_b = Button(8, invert=False)
button_c = Button(9, invert=False)
button_up = Button(22, invert=False)
button_down = Button(6, invert=False)
tempcolor = display.create_pen(0, 255, 0)  # this colour will get changed in a bit
humidcolor = display.create_pen(0, 255, 0)  # this colour will get changed in a bit
presscolor = display.create_pen(0, 255, 0)  # this colour will get changed in a bit
white = display.create_pen(255, 255, 255)
black = display.create_pen(0, 0, 0)
red = display.create_pen(255, 0, 0)
green = display.create_pen(0, 255, 0)
blue = display.create_pen(0, 0, 255)
yellow = display.create_pen(255, 255, 0)
orange = display.create_pen(255, 140, 0)
grey = display.create_pen(120, 120, 120)
violet = display.create_pen(255, 0, 255)
start_time = utime.time()
display.set_pen(black)
display.clear()
# converts the temperature into a description and pen colour
def describe_temperature(temperature):
    global tempcolor
    if temperature < 0:
        description = "Very Cold"
        tempcolor = blue
    elif 0 <= temperature < 12:
        description = "Cold"
        tempcolor = yellow
    elif 12 <= temperature < 17:
        description = "Cool"
        tempcolor = green
    elif 17 <= temperature < 22:
        description = "Warm"
        tempcolor = green
    elif 22 <= temperature < 27:
        description = "Hot"
        tempcolor = orange
    elif temperature >= 27:
        description = "Very Hot"
        tempcolor = red
    else:
        description = ""
        tempcolor = black
    return description
# converts humidity into good/bad description and pen color
def describe_humidity(humidity):
    global humidcolor
    if humidity < 30:
        description = "Low - Dry"
        humidcolor = orange
    elif 30 <= humidity <= 60:
        description = "OK"
        humidcolor = green
    elif 60 < humidity < 80:
        description = "High"
        humidcolor = yellow
    elif humidity >= 80:
        description = "Very High"
        humidcolor = red
    else:
        description = ""
        humidcolor = black
    return description
# converts pressure into barometer-type description and pen color
def describe_pressure(pressure):
    global presscolor
    if pressure < 982:
        description = "Very Low"
        presscolor = red
    elif 982 <= pressure < 1004:
        description = "Low"
        presscolor = yellow
    elif 1004 <= pressure < 1026:
        description = ""
        presscolor = green
    elif 1026 <= pressure < 1048:
        presscolor = blue
    elif pressure >= 1048:
        presscolor = orange
    else:
        description = ""
        presscolor = black
    return description
def draw_graph(temp_value, press_value, humid_value):
    scaled_temp = int((temperature * 5) + 160)
    scaled_humid = int((humidity * (320 / 100)) - 10)
    scaled_press = int(((pressuremb - 960) * 3) - 10)
    display.clear()
    display.set_pen(tempcolor)
    display.rectangle(0, 70, (scaled_temp), 19)
    display.circle((scaled_temp), 79, 9)
    display.text("{:0.0f}c".format(temperature), 0, 45, scale=3)
    display.text(describe_temperature(temperature), 150, 45, scale=3)
    display.circle((scaled_temp), 79, 5)
    display.set_pen(humidcolor)
    display.rectangle(0, 125, (scaled_humid), 19)
    display.circle((scaled_humid), 134, 9)
    display.text("{:0.0f}%".format(humidity), 0, 100, scale=3)
    display.text(describe_humidity(humidity), 150, 100, scale=3)
    display.circle((scaled_humid), 134, 5)
    describe_pressure(pressuremb)
    display.set_pen(presscolor)
    display.rectangle(0, 180, (scaled_press), 19)
    display.circle((scaled_press), 189, 9)
    display.text("{:0.0f}mb".format(pressuremb), 0, 155, scale=3)
    display.text(describe_pressure(pressuremb), 150, 155, scale=3)
    display.circle((scaled_press), 189, 5)
    display.set_pen(white)
    display.text("Enviromental Tricorder", 5, 10, scale=3)
    time_elapsed = utime.time() - start_time
    temperature, pressure, humidity = bme.read()
    pressuremb = pressure / 100
    draw_graph(temperature, pressure, humidity)
    vref_en.value(1)
    vdd = 1.24 * (65535 / vref_adc.read_u16())
    vbat = (
        (vbat_adc.read_u16() / 65535) * 3 * vdd
    )  # 3 in this is a gain, not rounding of 3.3V
    vref_en.value(0)
    percentage = 100 * ((vbat - empty_battery) / (full_battery - empty_battery))
    if percentage > 100:
        percentage = 100
    if percentage < 0:
        percentage = 0
    if usb_power.value() == 1:
        display.set_pen(blue)
        display.text("USB Powered", 75, 210, scale=3)
    else:
        display.set_pen(green)
        display.text("Battery", 0, 210, scale=2)
        display.text("{:0.2f}v".format(vbat), 75, 210, scale=2)
        display.text("{:0.0f}%".format(percentage), 150, 210, scale=2)
    if button_up.is_pressed:
    elif button_down.is_pressed:
        display.set_backlight(0.5)
    if time_elapsed < 1:
        display.clear()
        display.update()
        utime.sleep(1)
    else:
        display.update()
        utime.sleep(1)
        display.clear()
        utime.sleep(1)
