This is probably a really silly question but I’m stuck and need some help please!
I have just bought the Raspberry Pi 3 starter kit and a Unicorn PHat https://shop.pimoroni.com/products/unicorn-phat.
I have followed the instructions on https://learn.pimoroni.com/tutorial/unicorn-hat/getting-started-with-unicorn-hat, all the install and setup steps worked fine but I get an error when I try and run the simple.py program in the command line (as per the final instruction). The error reads “python: can’t open file ‘.simple.py’: [Errno 2] No such file or directory”.
‘simple.py’ does exist and has downloaded itself in the setup process (see attached photo!). I have tried using the filepath but that throws up the same error.
Am I doing something really obviously wrong!?.. I’m fairly convinced I am. Please help! L.E.D.'s would make me very happy.
Thank you in advance!
