[Unicorn Python] Keep led on without While True?
Hi all,
I don’t know if this is the good section to post this question, if not… please move it.
My question/what i’m trying to achieve:
  • I want to stop the Unicorn hat via a argument, so that i can turn things on and off, currently the only method i know to keep the leds on is with a While True: loop. I don’t want to exit the script with CTRL+C (or other keystroke) since i will make this command from Octoprint.
Currently, when the script runs with a While True:, i’m not able to stop it anymore with an argument; see example here.
#!/usr/bin/env python
import argparse
import unicornhat as unicorn
unicorn.set_layout(unicorn.PHAT)
unicorn.brightness(0.2)
parser = argparse.ArgumentParser()
parser.add_argument("-sw", "--show", action="store_true", help="turn on the led")
parser.add_argument("-st", "--stop", action="store_true", help="stop the led")
args = parser.parse_args()
if args.show:
    for x in range(8):
        unicorn.set_pixel(x, 1, 255, 0, 255)
    unicorn.show()
elif args.stop:
    unicorn.off()
Can someone please help me out? :)
This is actually a more complex problem than it outwardly appears. This is because, while the WS2812 LEDs on Unicorn HAT and Unicorn pHAT are “smart” and will remember the last data you sent to them, they’re also fairly forgiving about what they interpret as data.
Basically- if you’re not actively sending them a signal telling them to “show X” they might suddenly decide to interpret some random environmental noise as “show Y”, which isn’t fun!
Anyway, if you’re willing to overlook this detail you can fudge it by using adding:
unicorn.atexit._exithandlers = []
Right after unicorn.show()
It looks like I need to add this as a feature into Unicorn HAT, although because it has no onboard driver chip to maintain the last state you sent (causing the problem documented above) I’ve so far avoided doing so.
The correct way to accomplish this, would be to have the Python script running continuously, and then use some sort of interface (a fifo, pipe or otherwise) to communicate with that script and tell it to turn the lights on/off.
You could use SIGUSR1 and SIGUSR2 to do this, or perhaps SIGSTOP and SIGCONT. Off the top of my head:
import signal
def turn_on(signum, stack):
    for x in range(8):
    unicorn.show()
    signal.pause()
def turn_off(signum, stack):
    unicorn.off()
    signal.pause()
signal.signal(signal.SIGUSR1, turn_on)
signal.signal(signal.SIGUSR2, turn_off)
signal.pause()
Save this as unincornsignal.py and run with: sudo unicornsignal.py & to send it to the background.
You should see a line appear after this that says something like:
[2] 431
The latter number is the script’s PID, substitute this in the below commands.
Now try: sudo kill -12 PID to turn Unicorn HAT off
and sudo kill -10 PID to turn it on.
You could make a Python script to run these commands for you:
import os
import signal
import argparse
parser.add_argument("-pid", "--pid", type=int, help="pid of Unicorn Server")
if args.show:
    os.kill(args.pid, signal.SIGUSR1)
elif args.stop:
    os.kill(args.pid, signal.SIGUSR2)
And call with:
pi@raspberrypi:~ $ sudo python unicornremote.py --pid 464 --stop
pi@raspberrypi:~ $ sudo python unicornremote.py --pid 464 --show
And you could even go so far as to have unicornsignal.py save its pid to an external file, and have unicornremote.py read that in automatically.
Then set up a systemd unit to run your unicornsignal.py in the background:
[Unit]
Description=My UnicornHAT Server
After=multiuser.target
Requires=local-fs.target
[Service]
Restart=always
Type=simple
ExecStart=/usr/bin/python /home/pi/unicornsignal.py
[Install]
WantedBy=default.target
Which you would save as /etc/systemd/system/unicornserver.service
Then reload systemd:
sudo systemctl daemon-reload
And start your new service:
sudo systemctl start unicornserver
You can also get its status:
sudo systemctl status unicornserver
And stop it:
sudo systemctl stop unicornserver
