How would I code Blinkt to show red if a door’s closed, and green if it’s open?
I can do the magnetic switch OK, but can’t figure the code to get Blinkt to respond to changes in GPIO status.
Thank you.
Thank you.
Anyone? Must be possible…
You just want a loop continually reading the GPIO status and re-acting accordingly:
import RPi.GPIO as GPIO
from blinkt import *
GPIO.setmode(GPIO.BCM)
GPIO.setup(4, GPIO.IN)
switch_open = GPIO.input(4)
if switch_open:
for i in range(8):
set_pixel(i , 0, 255, 0)
else:
for i in range(8):
set_pixel(i , 255, 0, 0)
show()
was about to post an example too (using gpiozero and a button but same principle).
Note that you can use the set_all() function if you want all pixels to be the same colour.
Brilliant! Thank you, I’ll look at those over the next few days.
No worries, thought there might be a set_all type function, but the blinkt example I grabbed didn’t have an example of it :)
Just be mindful of whether your reed-switch (or equivalent) is wired up as pull-up or pull-down as it will affect the logic in my example.
That works just fine, thank you.
The set_all function is documented here: https://github.com/pimoroni/blinkt/blob/master/documentation/REFERENCE.md
How do you make it switch the LEDs off when you kill the script?
Try something like this:
… note there’s a dedicated doc site for a number of Pimoroni libs, with more added as time permits:
