Using another display with the Inky WHAT
Hi guys
I am working on a weather station project using a Pi zero 2 and an inky WHAT display.
I want to add a clock to the screen, but as I found out, the e-ink screen refresh rate is not good enough to have a clock. I think I will just need to refresh the inky screen once a day with the weather information.
So my next thought is to add a second OLED screen, and plug that into the breakout pins on the back of the inky screen.
I have found one on the PiHut website that looks like it has the same pins as the available ones on the inky screen :
The pins it has are :
3-6V
SDA
SCL
GND
Looking at the breakout on the inky, I have all of those available.
So will this screen work for what I want to do?
Another one I found on the site is this :
But it looks like it has pins like CS, COPI etc. And I don’t see those on the inky breakout.
Thanks for your help!
The first one, the OLED uses i2c,
1.12" Mono OLED (128x128, white/black) Breakout – I2C (pimoroni.com)
The second one uses SPI,
1.54" SPI Colour Square LCD (240x240) Breakout (pimoroni.com)
I’m using the OLED I linked too above, with my Inventor 2040 W. It’s used via Pico Graphics.
The I2C display will work, the SPI will probably also work, since it uses different CS and DC pins (sharing the SPI-bus with SCLK and MOSI is ok).
The big question is: why do you use an e-ink display, if you operate in always-on mode? E-inks are optimized for low-power, i.e. you update them, then turn the device of. If you are always on, you can find cheaper full-color displays and use only a single display.
Unrelated to your question, but related to your project: GitHub - bablokb/pi-e-ink-daily: Display Daily Agenda on an E-Ink Display
Although the repo title is about a daily agenda, I also use it as a weather forcast display (just scroll down).
This is my first project, and I did not know how these eInk displays work. I have a kindle, and it refreshes pretty quick, so I thought, that looks like it would be cool as a clock.
I like the viewing angles, and the fact that it takes very little power, so I was eventually going to add a battery etc.
But then when I started coding it up, I realised these screens arent really made for always-on type display. :(
SO my next thought was to have 2 displays. But I suppose I should just get an oled.
I was hoping there would be a way to just refresh part of the screen, but after a pretty exhaustive search online, I think that is impossible sadly.
I think the screen itself supports partial update. The problem is the Linux-driver that generates a complete image (canvas) and just sends that to the screen.
One thing in your argumentation is correct: the viewing angle is nice and it does not have such a glare as normal displays have. So there is some point to use it also as alway-on display. But you still have the problem of slow updates. The b&w Inky-wHat is rather fast compared to the color e-inks.
For larger color displays, have a look at what Waveshare offers. I have a number of displays from them, e.g. I am using a 4" touch spi-display and a 7" touch hdmi-display. These are not as nice as Pimoronis Hyperpixel displays, but they don’t use up all the GPIOs and are much cheaper.
@bablokb - Just took a look at your repo. Very impressive stuff!
I am working on my own version of the exact same thing, since I am learning python and coding on a PI, I wanted to start from scratch and figure it out myself. But your repo is going to help guide me, so thanks for sharing!
