Hello,
After update and upgrade my RPI3 I got this message… My son would like to start with his Explorer Hat but I cant get the i2c to work. Can anybody help me? i2cdetect -y 1 (at the bottom) did not retrun an adres…
Thanks!
Rikkert
@raspberrypi:~ $ sudo curl -sS https://get.pimoroni.com/envirophat | bash
This script will install everything needed to use
Enviro pHAT
Always be careful when running scripts and commands copied
from the internet. Ensure they are from a trusted source.
If you want to see what this script does before running it,
you should run: ‘curl https://get.pimoroni.com/envirophat’
Note: Enviro pHAT requires I2C communication
Do you wish to continue? [y/N] y
Checking environment…
Updating apt indexes…
Checking hardware requirements…
Checking for packages required for GPIO control…
…RPi.GPIO installed and up-to-date
I2C already enabled
Checking packages required by I2C interface…
…smbus installed and up-to-date
Enviro pHAT comes with examples and documentation that you may wish to install.
Performing a full install will ensure those resources are installed,
along with all required dependencies. It may however take a while!
Do you wish to perform a full install? [y/N] …y
Checking for dependencies…
Installing python-envirophat…
install ok installed
Installing python3-envirophat…
Checking for additional software…
Downloading examples and documentation…
Resources for your Enviro pHAT were copied to
/home/pi/Pimoroni/envirophat
All done. Enjoy your Enviro pHAT!
pi@raspberrypi:~ python -c 'import time, explorerhat; explorerhat.light.on(); time.sleep(1); explorerhat.light.off()'
Warning, could not find Analog or Touch...
Please check your i2c settings!
pi@raspberrypi:~ ^C
pi@raspberrypi:~ $ i2cdetect -y 1
70: – -- – -- – -- – --
