I need direct access to gpio pins. So, I think that excludes Explorer Hat/Pro. I was thinking to get the Propeller HAT because it seems to give access to direct gpio pins, 5V vcc and 3.3V vcc, and that’s all I need. But I just want to be sure before placing my order. Will it work ? Or should I get an Adafruit T-Cobbler with a classic mini breadboard ? I’d rather go with the Propeller HAT as it fits perfectly in the pibow coupé. I don’t want a breadboard hanging around my RPi.
Hum, a HAT, by definition, does not allow direct access to GPIO, as the specs do not cater for stacking. Some however, like the Explorer/Propeller, do indeed provide a breakout for some of the pins, but not all.
I’m confused though, why would you need one of those HAT involved for your project?
I just want a hat because it fits perfectly on a Pibow Coupé case.
If I get a breadboard ad a Cobbler, it doesn’t fit on a pibow coupé case and it will hang around, it’s just not practical under my TV. Unless there is seach a breadboard that fits on a case ?
You could even stick a breadboard on top if you really wanted to, though again, soldering in permanent position is what will give you the least trouble long term.
Ok then, I will listen to you and I will solder directly on adafruit Perma-Proto. My main concern is that if I wrongly wire the schema, will I be able to undo and solder again or I need to buy another Perma-Proto?
Desoldering single points is not that much of a problem. I haven’t tried the perma-proto myself but expect the contacts to be high quality and survive such treatments.
Thanks RogueM for pointing me this link ! It’s nice because I do not solder directly on the Raspberry but on that HEADER, right ?
I will also get a breadboard for testing out my connections before soldering directly on the pcb. Gosh I haven’t soldered anything since my studies, 10 years ago !
No, you’d still use the perma-proto breakout to access the GPIO you need, but using a header with extra tall pins allows you to stack a HAT on the top of your IR circuit if you wanted to at a later point.
… That’s just a suggestion though, since you have a choice of which header to solder to the perma-proto. Soldering the header that comes with it will be slightly easier, but this will give you room to expand.
Sorry, I misspoke what I wanted to say. I thought that HEADER would clip directly on the RPi, and then I would solder my perma-proto on it, rather than soldering the perma-proto on the RPi itself.
Sorry for the spelling mistakes, I’m a french guy ;-)
Oh thanks :) I think it’s better to continue here for sharing informations to those who face the same questions, even if it would be way more convenient for me to speak in french :)
So, to sum it up, I need :
The HEADER that connects to the RPi - no soldering required. It allows the HAT to be placed on top of USB/RJ45 port
Is that right ? Though I’m wondering why I would need that particular HEADER as it seems that there’s already one bundled with the perma-proto hat mini kit. In fact, I don’t plan in the near future to stack other hats.
And finally, would that fit in the Pibow Coupé ? Or I need to let my RPi naked ?
Yes, the perma-proto comes with a header. If you don’t plan to add a HAT then the other one is not necessary. Be aware that you will not be able to desolder a 2x20 header later on though.
The pibow Coupé brings in no particular physical restriction, from the point of view of access to GPIO or attaching add-on boards it is very much like having a bare RPi.
