I have a RPI3+ with Iqaudio amp hat, which uses a 19volt power supply. Can I use the onoff shim to control it? I have used it on other builds but they are only the standard RPI3 power. So is 19v within its power handling.
hello and welcome to pimoroni forums , no, according to the description,it says * Supports up to 2.5A power supply ,https://shop.pimoroni.com/products/onoff-shim
ok thanks mine pulls 3.15a, thats a bugger, now i guess i will have to find some other way to send a signal to the Pi to shut down the shim just works so well. thanks
