WIP Tufty2040 thing :)
Making an animation for my LCD con badge (Tufty). :3 The hills have a parallax effect, the fox is running (sprite sheet), the stars twinkle, there are shooting stars (rarely!). I’m now adding a day/night system!
The hills are just quantized sin waves, filled with quads underneath, lol.
It seems to run nice and smooth, looking forward to adding more cool stuff before frame rate takes a hit xD
I had to get creative with the sprite sheet thing, given the 8x8 requirement, so that fox sprite is actually about 6 different sprite draw calls per frame, haha.
How do you nominate a color to be the alpha channel?
Drawing Sprites - Picographics
Argument number 6 – which will be a colour you defined as so:
So for me:
display.sprite(x1, y1, position_x + 0 * 8, position_y, scale, BLACK)
Can you share your full code? Thanks :)
Good luck. I haven’t organised or optimised it yet. :)
# This is a Tufty2040 with VERY limited memory and processing power.
from picographics import PicoGraphics, DISPLAY_TUFTY_2040
import random
import math
display = PicoGraphics(display=DISPLAY_TUFTY_2040)
loop_time = 0.01
NAVY_BLUE = display.create_pen(0, 0, 100)
MOON_COLOR = display.create_pen(255, 255, 224)
GREEN = display.create_pen(0, 190, 0)
MED_GREEN = display.create_pen(0, 135, 0)
DARK_GREEN = display.create_pen(0, 65, 0)
hill_height = HEIGHT // 4
hill_frequency = 2 * math.pi / WIDTH * 2.0
x_phase = 0
y_phase = HEIGHT // 2
num_rectangles = 60
def draw_hill(display, hill_height, hill_frequency, x_phase, y_phase, num_rectangles, colour):
    rect_width = WIDTH // num_rectangles
    gap = WIDTH % num_rectangles
    display.set_pen(colour)
    x = 0
    for i in range(num_rectangles):
        extra_gap = 1 if i < gap else 0
        actual_rect_width = rect_width + extra_gap
        y = int(y_phase + hill_height * math.sin(hill_frequency * (x - x_phase)))
        rect_height = HEIGHT - y
        display.rectangle(x, y, actual_rect_width, rect_height)
        x += actual_rect_width
def draw_hills():
    t  = time.ticks_ms()
    t1 = t / 10.0
    t2 = t / 20.0
    t3 = t / 30.0
    draw_hill(display, hill_height * 0.3, hill_frequency * 0.9, x_phase                           - t3, y_phase - 20, num_rectangles, DARK_GREEN)
    draw_hill(display, hill_height * 0.2, hill_frequency * 0.6, x_phase - (WIDTH * 0.3)           - t2, y_phase + 00, num_rectangles, MED_GREEN)
    draw_hill(display, hill_height * 0.1, hill_frequency * 0.4, x_phase - (WIDTH * 0.3 * 2)       - t1, y_phase + 50, num_rectangles, GREEN)
# Stars
NUM_STARS = 50
stars = [(random.randint(0, WIDTH-1), random.randint(0, (HEIGHT-1) // 2)) for _ in range(NUM_STARS)]
shooting_star_active = False
shooting_star_x = 0
shooting_star_y = 0
shooting_star_vx = 0
shooting_star_vy = 0
TRAIL_LENGTH = 80
def draw_nightsky():
    global shooting_star_active, shooting_star_x, shooting_star_y, shooting_star_vx, shooting_star_vy
    display.set_pen(NAVY_BLUE)
    display.rectangle(0, 0, WIDTH, HEIGHT)
    moon_x, moon_y, moon_radius = WIDTH // 8, HEIGHT // 8, 15
    display.set_pen(MOON_COLOR)
    display.circle(moon_x, moon_y, moon_radius)
    # Draw Stars
    display.set_pen(WHITE)
    for x, y in stars:
        if random.randint(0, 100) > 5:
            display.circle(x, y, 1)
    if shooting_star_active:
        shooting_star_x += shooting_star_vx
        shooting_star_y += shooting_star_vy
        for i in range(TRAIL_LENGTH):
            display.circle(int(shooting_star_x - i * shooting_star_vx / TRAIL_LENGTH),
                           int(shooting_star_y - i * shooting_star_vy / TRAIL_LENGTH), 1)
        if shooting_star_x > WIDTH or shooting_star_y > HEIGHT:
    else:
        if random.randint(0, 1000) > 975:
            shooting_star_active = True
            shooting_star_x, shooting_star_y = random.randint(0, WIDTH//2), random.randint(0, HEIGHT//4)
            angle_deg = random.uniform(-45, 45)
            angle_rad = math.radians(angle_deg)
            speed = random.uniform(20, 30)
            shooting_star_vx = speed * math.cos(angle_rad)
            shooting_star_vy = speed * math.sin(angle_rad)
frame = 0
speed = 70.5
time_per_frame = 1.0 / speed
time_counter = 0.0
display.set_font("bitmap8")
display.load_spritesheet("foo.rgb332")
def draw_fox(x1, x2, x3, y1, y2, position_x, position_y, scale):
    display.sprite(x2, y1, position_x + 1 * 8 * scale, position_y,             scale, BLACK)
    display.sprite(x3, y1, position_x + 2 * 8 * scale, position_y,             scale, BLACK)
    display.sprite(x1, y2, position_x + 0 * 8,         position_y + 8 * scale, scale, BLACK)
    display.sprite(x2, y2, position_x + 1 * 8 * scale, position_y + 8 * scale, scale, BLACK)
    display.sprite(x3, y2, position_x + 2 * 8 * scale, position_y + 8 * scale, scale, BLACK)
def draw_running_fox():
    global frame, time_counter
    scale = 4
    position_x = 160
    position_y = 140
    if frame == 0:
        draw_fox(0, 1, 2, 0, 1, position_x, position_y, scale)
    elif frame == 1:
        draw_fox(3, 4, 5, 0, 1, position_x, position_y, scale)
    elif frame == 2:
        draw_fox(6, 7, 8, 0, 1, position_x, position_y, scale)
    elif frame == 3:
        draw_fox(9, 10, 11, 0, 1, position_x, position_y, scale)
    elif frame == 4:
        draw_fox(12, 13, 14, 0, 1, position_x, position_y, scale)
    elif frame == 5:
        draw_fox(0, 1, 2, 2, 3, position_x, position_y, scale)
    elif frame == 6:
        draw_fox(3, 4, 5, 2, 3, position_x, position_y, scale)
    elif frame == 7:
        draw_fox(6, 7, 8, 2, 3, position_x, position_y, scale)
    time_counter += 0.05
    if time_counter >= time_per_frame:
        frame += 1
        if frame > 7:
            frame = 0
        time_counter -= time_per_frame
    draw_nightsky()
    draw_hills()
    draw_running_fox()
    display.update()
    time.sleep(loop_time)
There’s a reason those draw_fox indices are the way they are! We have to draw 6 8x8 sprites per frame:
Credit to hdst at OpenGameArt for the sprites:
hdst fox assets
