Pirate Radio VLCd stop after 1-2 min
Hello,
I have just received and assembled my Pirate Radio.
It’s installed with 2017-08-16-raspbian-stretch-lite.img
The installation was ok.
When i reboot, the music start and stop after 1 or 2minutes.
The process VLC stopped.
I try ti use several radio and none of them played for a long time.
the vlc log file contains warning
pi@raspberrypi:/var/run/vlcd $ more vlcd.log
– logger module started –
core error: no suitable interface module
core error: interface “globalhotkeys,none” initialization failed
dbus error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
core error: interface “dbus,none” initialization failed
dummy: using the dummy interface module…
core: stopping playback
es error: cannot peek
http warning: ICY metaint=16000
http: Raw-audio server found, mp3 demuxer selected
alsa warning: device cannot be paused
mpgatofixed32 error: libmad error: bad main_data_begin pointer
core warning: playback too early (-40001): down-sampling
core warning: playback too early (-40029): down-sampling
Can anybody help me ?
Thanks in advance
This seems to have cropped up recently with Stretch and I’m not quite sure what’s going on yet. There have been a few other reports of similar crashing problems with VLC, though, so you’re not alone.
http://forums.pimoroni.com/t/pirate-radio-kit/5806
http://forums.pimoroni.com/t/pirate-radio-after-update-from-jessie-to-stretch-instable/5698
You might find it works fine if you switch to Jessie for now: https://downloads.raspberrypi.org/raspbian_lite/images/raspbian_lite-2017-07-05/2017-07-05-raspbian-jessie-lite.zip
I don’t know what’s up in Stretch yet, but I’m looking into it.
Thanks for this answer.
I’m going to install Rasbian jessie on another microSD card and i keep you in touch.
Hello
After a full new install in Jessie version of Raspbian, everythink works fine !
Thank you
