240x240 LCD how to change backlight pin on Pi Pico
I have a 1.3" SPI Colour Square LCD (240x240) Breakout which I want to use with a Pi Pico W and micropython.
However the default pins are not available.
These are the defaults
  • 3-5V to any 5V or 3V pin
  • CS to GP17
  • SCK to GP18
  • MOSI to GP19
  • DC to GP16
  • BL to GP20
  • GND to any ground pin
I know how to change the SPI pins but not how to change the backlight pin
changing the SPI pins: (default values for illustration)
    from pimoroni_bus import SPIBus
    from picographics import PicoGraphics, DISPLAY_LCD_240X240, PEN_P8
    spibus = SPIBus(cs=17, dc=16, sck=18, mosi=19)
    display = PicoGraphics(display=DISPLAY_LCD_240X240,, bus=spibus, pen_type=PEN_P8)
I want to make use of the display.set_backlight(0.5) command but I need to specify a pin other than GP20
can someone point me to where I can change the default backlight pin please?
cheers
Alex
Just add the bl= at the end. I did this on a dual display setup I use on a Pico.
spibus_R = SPIBus(cs=17, dc=16, sck=18, mosi=19, bl=20)
spibus_L = SPIBus(cs=22, dc=16, sck=18, mosi=19, bl=21)
that simple!
brilliant.
many thanks
Alex
If only all problems were that simple to fix. ;)
