6 Plasma buttons not working
I’ve checked the wiring to the xhat twice and still I can only get the front and side buttons to light up. Oh, my B button does light up but the rest either flicker or don’t light up at all.
Any tips or advice would be great!
Richard
It’s likely the wiring between the last button that works and the first one that doesn’t in the chain. Double check you haven’t got the two jacks on the button reversed. If it’s not that I would swap out the cable between the buttons first, and if that doesn’t work, swap out the plasma part of the button or bypass it if possible.
I will try to rewire the six buttons again. Thanks!
