I am trying to use a RTC Backup for my Raspberry Pi 4 with an Automation Hat (PIM213), and to do so I need to be able to access a 3V3, GND, SCL and SDA pin. 3V3, GND, and SCL are accessible from the center of the hat, but from what I read in other forum threads the SDA pin is hooked up to the ADC section of the hat.
I was wondering if it would be possible to access that pin, either by configuring the hat to let the signal through, or maybe even accessing the pin directly underneath the hat, while the hat is plugged into the pi. Would either of these work? Is there anything I can do, or do I need to think about changing what hardware I am using?
