Adafruit ESP32-S3 Feather and CharliePlex IS31FL3731 FeatherWing
Hoping someone can advise.
I’m using the Adafruit ESP32-S3 Feather, and want to drive the Adafruit 15x7 CharliePlex LED Matrix FeatherWing.
The demo code that comes with Adafruit_IS31FL3731 library works well on other feathers, but although it compiles and uploads to the ESP32-S3 Feather, it doesn’t light any LEDs.
I wonder if I’m missing something obvious - any help would be much appreciated.
Using SDA/SCL for data/clock.
3V and GND for power.
The code I am using is
swirldemo.ino
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_IS31FL3731.h>
// If you're using the full breakout...
//Adafruit_IS31FL3731 ledmatrix = Adafruit_IS31FL3731();
// If you're using the FeatherWing version
Adafruit_IS31FL3731_Wing ledmatrix = Adafruit_IS31FL3731_Wing();
// The lookup table to make the brightness changes be more visible
uint8_t sweep[] = {1, 2, 3, 4, 6, 8, 10, 15, 20, 30, 40, 60, 60, 40, 30, 20, 15, 10, 8, 6, 4, 3, 2, 1};
void setup() {
  Serial.begin(9600);
  Serial.println("ISSI swirl test");
  if (! ledmatrix.begin()) {
    Serial.println("IS31 not found");
    while (1);
  Serial.println("IS31 found!");
void loop() {
  // animate over all the pixels, and set the brightness from the sweep table
  for (uint8_t incr = 0; incr < 24; incr++)
    for (uint8_t x = 0; x < 16; x++)
      for (uint8_t y = 0; y < 9; y++)
        ledmatrix.drawPixel(x, y, sweep[(x+y+incr)%24]);
  delay(20);
Serial Monitor output:
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
invalid header: 0xffffffff
ets Jul 29 2019 12:21:46
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 271414342, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5856
entry 0x400806a8
NOTE - the board is actually Adafruit ESP32 Feather V2 - 8MB Flash + 2 MB PSRAM - STEMMA QT
When I change the Serial baud rate from 9600 to 115200
  Serial.begin(115200);
I get different info from the Serial Monitor:
Rebooting...
entry 0x400806a8
ISSI swirl test
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC      : 0x40080f85  PS      : 0x00060d30  A0      : 0x800d28d7  A1      : 0x3ffb1ed0
A2      : 0x00000016  A3      : 0x00000016  A4      : 0x00000000  A5      : 0x00000064
A6      : 0x00000000  A7      : 0x60013000  A8      : 0x3f400d4c  A9      : 0xffffffff
A10     : 0xffffffff  A11     : 0x00000080  A12     : 0x00000000  A13     : 0x00000000
A14     : 0x00000000  A15     : 0x00000000  SAR     : 0x00000009  EXCCAUSE: 0x0000001c
EXCVADDR: 0xffffffff  LBEG    : 0x400014fd  LEND    : 0x4000150d  LCOUNT  : 0xffffffff
ELF file SHA256: 0000000000000000
Backtrace: 0x40080f85:0x3ffb1ed0 0x400d28d4:0x3ffb1ef0 0x400d0e7c:0x3ffb1f20 0x400d1499:0x3ffb1f40 0x400d17f1:0x3ffb1f60 0x400d0cec:0x3ffb1f80 0x400d33e6:0x3ffb1fb0 0x400869bd:0x3ffb1fd0
Apologies!
I was using the wrong board in >Tools>Boards Manager…
Solved/
