Does the Adafruit Micro SD card also work with the Pi Zero? I see the usual excellent documentation for Arduino and was wondering if this board was Pi friendly as well?
What do you want to do with it? Add a second SD card to the Pi? There has been some work done on it: https://ralimtek.com/raspberry%20pi/electronics/software/raspberry_pi_secondary_sd_card/
Hi, yes I am after adding a second SD card for storage that can be easily removed without causing any problems as if I was to remove the main card. Thanks for the link, this looks like what I need, will give it a go!
