I have my speaker phat working over airplay with your one line installer but a couple of things have come to my attention.
Firstly the vu meter is not working. Is this expected behaviour?
Secondly I can now not play mp3 files normally. Is this expected? If not how can I change it back so I just have a normal speaker phat which I can play mp3’s off?
I think there is currnently an issue with the vu meters when playing through airplay, which we are looking into.
… we are using a pre-compiled version of shairport-sync that is part of raspbian testing (so ahead of debian/raspbian ‘stretch’) and it’s possible that the most recent push has broken something.
you can disable the shairport-sync service, or uninstall it altogether, though from what we observed today if what you want is to play files locally then playback+vu will work regardless of the service running or not.
I’ll have to check it to be sure… can’t say I have been testing on the latest Raspbian image much - we were discussing this right now in our slack channel, it could possibly be some OS-level change.
it works here on jessie lite… to be honest I have never tried it in Raspbian full, cause there is little point throwing THAT kitchen sink in for an airplay speaker, is that Jessie Full (with Pixel) you are running?
Right so I have tried again with the surface script and it now doesn’t show up on my phone so is there an update to shairpoint sync that could be affecting the script?
I have also just tried speaker phat install again and nothing happened there I just got the same error
hum, as long as your Pi is on the same network as your phone then you should see it as an airplay output.
I’ll have to try it against a full raspbian image - @sandyjmacdonald and I certainly struggled to get the VU meter going yesterday in that environment - but audio was working fine.
In the meantime, you could try option 1 - pHAT DAC - in the airplay insaller, which may cause you less trouble but won’t support the VU LEDs. Or use a fresh Raspbian Jesie Lite image which, at least at my end, seems to work (including VU for Speaker pHAT and pHAT BEAT).
interestingly ‘default’ is the placeholder name in the asound.conf so I’m wondering if the value replacement that the script attempts (for Speaker pHAT and pHAT BEAT) is failing for you for some reasons.
… check /etc/asound.conf and verify that the output_device value under the pivumeter scope corresponds to your device.
So when I play an mp3 through command line with mpg321
So this is the readout
High Performance MPEG 1.0/2.0/2.5 Audio Player for Layer 1, 2, and 3.
Version 0.3.2-1 (2012/03/25). Written and copyrights by Joe Drew,
now maintained by Nanakos Chrysostomos and others.
Uses code from various people. See ‘README’ for more!
THIS SOFTWARE COMES WITH ABSOLUTELY NO WARRANTY! USE AT YOUR OWN RISK!
Playing MPEG stream from Beethoven_fith_symphony.mp3 …
MPEG 1.0 layer III, 128 kbit/s, 44100 Hz joint-stereo
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm_meter.c:678:(snd_pcm_meter_add_scope_conf) Cannot open shared library /usr/local/lib/libpivumeter.so
I’m not sure to be honest. Just tried with mpg321 here to be sure and it works perfectly.
just to clarify, what Pi is this on? and this is with Jessie Pixel, not Lite, correct? did the compilation process of libpivumeter fail in any way? and if you airplay you get sounds but no VU (but sounds work)?
… if you are in at the weekend / Pi Party, come and see me/us… perhaps you can bring along that SD so I can check a few things. The mp3 you are using could be useful as well, if that is OK for you to leave a copy with us.
I’m in the process of assembling a few test files to try to channel troubleshooting meaningfully and I’ll let you know when they are up and how to use them.
After seeing you today I have made a fresh install of Jessie lite and have run the installer. The installer runs I see airplay on my phone. I connect and then nothing no audio or vu at all. No idea what is going on!
