I have a problem with my pi400 with latest version of Pi OS.
Arduino 1.8.13 (arm32) installs fine apart from the following (very common) error:
sudo ./install.sh Adding desktop shortcut, menu item and file associations for Arduino IDE... touch: cannot touch '/root/.config/mimeapps.list': No such file or directory /usr/bin/xdg-mime: 848: /usr/bin/xdg-mime: cannot create /root/.config/mimeapps.list.new: Directory nonexistent done!
It starts fine.
It adds boards and libraries (inc the new PiPico lib) fine.
It uploads sketches fine.
It talks to a board over serial.
It closes fine.
Will it then start up again? Does it ‘bleep’ as like!! The splash screen appears and then disappears, I get a pointer with hourglass for a few seconds then nothing!. Rebooting doesn’t help.
I’ve found the same problem with a Pi3A+. I’ve even tried running Arduino 1.8.6 (on the 3A+) and that wont even start once!
Andrew
PS is there a command to remove all traces of arduino 1.8.13 from PI OS system files?
